Thread started 15 Sep 2006 (Friday) 17:48
Canon 35mm f2 opinions?
DaveSt
Sep 15, 2006 17:48 |  #1
I don't see much talk about this lens, but a 35mm lens seems like it would be about perfect on a crop sensor camera. Does anyone here use this lens, and if so how do you like it? I have the 50mm f/1.8 II and I love the sharpness and the ability to get good shots in low light, but the length is a little long on my 300D for my tastes.
Dave
[30D] [Sigma 30 f/1.4] [50 f/1.8] [EF-S 60] [EF-S 15-85IS] [EF-S 55-250IS] [Sigma EF-500 DG Super]
steved110
Sep 15, 2006 17:54 |  #2
It's a nice lens, and a reasonable price - and on a crop camera gives a nice FOV, very similar to the 50mm 'standard' you get with film and FF cameras.
Read a review HERE (external link)
Personally I'd rather spend a little more amd get the sigma 30mm f/1.4 - this works out at 48mm equivalent, and comes with a case and hood, and optically gives the 35mm f/1.4 L a run for the money. I was looking at the 35mm f/2 seriously but the sigma has such a good rep now, having overcome earlier quality control issues, that I decided to the sigma was better value.
come christmas time, it will be mine, my precious.....;)
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
Bill ­ Roberts
revolting peasant
Sep 15, 2006 18:13 |  #3
If you like fast primes, then anything around 30 - 35mm makes a very useful "walk around" lens. I probably use mine more often than any other lens I have. Irrespective of which you finally choose the Canon f/2 or f/1.4 or the Sigma 30mm f/1.4 I doubt that any of them would disappoint you.
cheers
Bill
BiLL
kidpower
Sep 15, 2006 18:40 as a reply to  @ Bill Roberts's post |  #4
I have it and use it a fair amount of time. It's a little soft wide open at F2 (but certainly useable). It's a very sharp lens from F4-F8, which won't help you much indoors. For my uses it's a great lens.
FlashZebra
This space available
Sep 16, 2006 01:44 |  #5
Here is another review:
http://www.photozone.d​e …nses/canon_35_2​/index.htm (external link)
Enjoy! Lon
chtgrubbs
Joined Jul 2003
Sep 16, 2006 12:36 |  #6
It's very sharp, has excellent color and contrast. It's not USM, so there is some noise when it focusses, but it has never bothered me. This is a 100% crop from a 5D body:
Double ­ Negative
*sniffles*
Sep 17, 2006 08:56 |  #7
I used this lens as my main lens for several years. It's compact, light and very sharp. Relatively low-cost. Takes wonderful pictures.
The downsides are the ancient AF - it's slow and buzzy. But don't let this stop you as it's more than usable and really not *that* bad. One thing that's nice is the lens has a really short minimum focusing distance (9" or so) which lets you get near-macro. Throw on a dioptre lens or three and you're there.
On crop cameras (especially 1.6x) it's the most useful focal length around - very close to a "standard 50mm" lens. It was a perfect match to my D30.
Due to its size, it's very stealthy for candid/street photography.
I just love this lens. It's one of Canon's most underrated lenses, IMO. In the sweet spot, it's sharper than many lenses in the lineup.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
mfunnell
Sep 17, 2006 09:00 |  #8
I like mine a lot and use it almost as often as my 50.
...Mike
Some digital cameras, some film cameras, some lenses & other kit.
Day-to-day photos on flickr (external link), some older stuff at dA (external link).
DaveSt
Sep 17, 2006 12:46 as a reply to  @ mfunnell's post |  #9
Thanks alot for the replies. I have been debating among the 35 f/2, the 28/f2.8 and the Sigma 30 f/1.4 for my next lens.
For the people using the 35 f/2, how is the indoor performance of the lens? I am hoping to use this lens as my primary indoor lens when lighting is troublesome. My 50mm works pretty well in these conditions, but it is just too long to be of much use indoors.
Dave
LightRules
Return of the Jedi
Joined Jun 2005
Sep 17, 2006 12:54 |  #10
I used the 35f2 for several years and now the 30f1.4. I can't see for the life of me how they are comparable. We're talking about a lens that at f1.4 easily outresolves the Canon at f2.8. Build quality is also far apart, and the Sigma has ring HSM with FTM. Yes the 35f2 is a "good" lens, but in all honesty, it isn't close. Of course, the EX is limited to APS-C...but that's not news.
Double ­ Negative
*sniffles*
Sep 18, 2006 09:06 |  #11
That's just it - if you don't have EF-S you don't have much of a choice in the 30-35mm range. But like fStopJojo said; the build quality is completely different.
Optically the 35mm f/2.0 is pretty darn good. It's just what the glass comes in that's a little weak. ;)
Nevertheless for the money it's a great lens. As for using it indoors, it's really not bad. While it's certainly not a f/1.4 it gets the job done if you bump the ISO as needed. Dims pubs and restaurants give it trouble and a flash is really necessary - but normal room lighting is doable.
Most of my lenses are f/2.8 - so using f/2.0 certainly helps in my case. ;)
lensview
Sep 18, 2006 09:27 as a reply to  @ Double Negative's post |  #12
A very good tiny lens. Unfortunately, right now I can not locate more illustrative photos than these below, but at least will give you something. (I think those are unprocessed JPG on MkIIN).
Canon SD600
Sandisk 1Mb ExtraIII SD card
2,072 views & 0 likes for this thread, 10 members have posted to it.
2790 guests, 154 members online
