Can someone please tell me what the adjustable ring on my polarizer filter is for? It seems to just turn freely and I am not at all sure what the purpose of this is.
Montec Member 61 posts Joined Aug 2006 More info | Sep 15, 2006 20:15 | #1 Can someone please tell me what the adjustable ring on my polarizer filter is for? It seems to just turn freely and I am not at all sure what the purpose of this is.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Sep 15, 2006 20:18 | #2 Think of a polarizer as a device with a lot of 'optical slits' all parallel. When omnidirectional light passes thru, the rays which run parallel to the slits go thru, the rays which run perpendicular to the slits get blocked. The result is that reflections (polarized light) get blocked if oriented perpendicular to the slits in the filter. The ring allows you to orient the slits in the filter. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Sep 15, 2006 20:23 | #3 Thanks, that makes sense...but how do you tell which was they are oriented? It looks all the same to me.
Pete I was "Prime Mover" many years back.... 38,631 posts Likes: 25 Joined Jul 2006 Location: Berkshire, UK More info | Sep 15, 2006 20:30 | #4 You'll be able to see the effect through the viewfinder. Just point the lens at a window with reflections and twist the filter while looking through the viewfinder and you'll see the effect come and go. Depending on your angle to the sun, you'll also be able to see the effect on the blueness of the sky.
tracerbullet Senior Member 282 posts Joined Dec 2005 Location: St. Paul, MN More info | Sep 15, 2006 22:00 | #5 There is no real setting on a polarizer, no right or wrong, "this way up", or anything like that. As was mentioned, you decide if you need it or not, install it if you do, then just turn it and look through the viewfinder to get the effect you want. http:// …Gear List
Sep 15, 2006 22:17 | #6 Thanks all...makes sense now
| Latest registered member was a spammer, and banned as such! 2881 guests, 176 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
