Thread started 16 Sep 2006 (Saturday) 17:41
CC: Barnhouse HDR using Layers & Curves only
fivefish
Sep 16, 2006 17:41 |  #1
Took this picture this afternoon.... HDR (from a single photo) using layers in photoshop. Took about an hour to do it, but I'm very happy with the result. Printed on an 8x11 looks great. Also zoomed in at 100% looks great, and you can see all the detail on the roof and in the shadows.
No polarizer... just my 30D and 24-105 f4L IS lens, and Canon UV/Haze lens filter...
The photoshop layers and masks.
Save money! Check out my DIY projects (external link)!
Canon EOS 30D, Canon Digital Rebel
Canon 10-22mm EFS, 70-200mm f4L, 24-105 f4L IS
Canon 50mm f1.8 EF, Canon 75-300mm EF lens
Sigma 150mm Macro, Canon 380EX Flash
DIY High-Speed Sound-activated Flash Trigger and Nikon SB-26 Flash
Hellashot
Joined Sep 2004
Sep 16, 2006 20:11 |  #2
Hardly a HDR shot. I lighten shadows and darken highlights on almost all of my shots and I don't consider that "hdr". There are too much shadows to call it what people like as "hdr", sorry.
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
fivefish
Sep 16, 2006 23:26 |  #3
If you're referring to glowing buildings and cartoonish-looking shots, that's not what I'm after. I don't prefer those kind of shots. Maybe you, but not me.
MitsuJDM
Sep 16, 2006 23:44 |  #4
HDR is a process, not a "look".
I do believe your shot is fantastic though :)
350D+grip+lenses
http://www.flickr.com/​photos/rkmphotography/ (external link)http://www.flickr.com/​photos/rkmphotography/ (external link)
mlc
Sep 17, 2006 03:57 as a reply to  @ MitsuJDM's post |  #5
Sorry to be ignorant but what does HDR stand for?
Mike
5D Mk3; 7D; 24-105 F4; 70-200 F2.8 Mk2; 300 F2.8 Mk2; 500 F4 Mk2;1.4x and 2x Mk 3 Extenders; 055CXPRO3; Benro GH2
Guineh
Sep 17, 2006 09:41 |  #6
Hellashot wrote in post #1996168 (external link)
If the OP is using multiple exposures, it could be considred hdr, but hdr is a way of automating getting the most range out of a photo.
fivefish wrote in post #1996797 (external link)
Done properly an HDR shot should be indistinguishable from a normal picture. These with glowing buildings, or strange tonality are not what the tool was designed for. To be honest, I've had better luck lately just taking 2 or 3 exposures and combining them by masking too dark areas out.
mlc wrote in post #1997511 (external link)
High dynamic range. Instead of storing the color values as discrete numbers (0-255 or 0-65535), its stored as a floating point value, allowing for a great amount of range. Of course, this range cannot be represented on the screen, so it must be compressed into the ranges shown above. Note that 16 bit does allow for a significant amount more color information, it is not considered HDR. HDR is theoretically able to capture details in the very darkest shadows, all the way to the brightness of the sun. By compressing the resulting range, you can do what was traditionally done with a graduated neutral density filter, and beyond.
HDR images are also being used by some 3D rendering packages to add realism to a scene. Bright highlights in the photo act as light sources, just as they would in the real world (and I think this is where HDR really shines)
The glowing edges you see in some HDR images is actually the result of improper technique with the local adaptation method of range compression. Local adaptation works by isolating areas and adjusting the level of that small area accordingly. If the right radius and threhold are picked (in photoshop, not sure about others) there should be little to no haloing.
Mr. ­ E
Joined Nov 2005
Sep 17, 2006 11:30 |  #7
bannedPermanently
I didn't understand HDR (actaully, never heard of it) until this post and the above explanation. Based on that, I can see the effect in the barn against the backgound- especially at right of the barn. If I'm wrong, that's my own ignorance. Overall, I think it's a great shot. I love the brightness of the colors and the overall composotion of the shot. If you own the barn, you might want to plant a tree/ bush (even temporarily- unless you can plant one there in PP) to hide the meter (or whatever it is) behind the pond; it looks out of place.
1,567 views & 0 likes for this thread, 6 members have posted to it.
1706 guests, 169 members online
