Thread started 18 Sep 2006 (Monday) 07:08
My 35L went through "Tilt Adjustment" ...
roli_bark
Sep 18, 2006 07:08 |  #1
My 35L (which was badly front focussing), was turned-in to Canon (NJ) for a mend.
It came back with a note detailing the work which has been carried out:
1. Focus Adjustment,
2. Tilt Adjustment
What is the reason for fix [2] ?
What are the visible symptoms with PICs shot with a lens that needs a "Tilt Adjustment"
Thnx ...
steved110
Sep 18, 2006 07:53 |  #2
I would assume something inside was tilted out of alignment, so they adjusted it. what matters most is, does it work properly now?
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
AeroSmith
Gallery: 46 photos
Joined Feb 2006
Sep 18, 2006 08:13 as a reply to  @ steved110's post |  #3
Yeah, how is it now? Did they do a good job? I just sent a lens into Canon's NJ center for a focus adjustment.
Josh Smith
lensview
Sep 18, 2006 08:31 |  #4
roli_bark wrote in post #2002023 (external link)
2. Tilt Adjustment
Thnx ...
Very interesting. I have heard of lens element "centering" (apparently the EF 50mm f/1.0 L USM was provisioned with a centering adjustment feature).
Did the lens exibit uequal sharpnes one side vs. the other ?
Canon SD600
Sandisk 1Mb ExtraIII SD card
Andy_T
Joined Jan 2003
Sep 18, 2006 08:56 |  #5
No hard experiences with that, but I would assume that one side is in focus, while the other is not. Also refered to as 'centering', I think.
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
roli_bark
Sep 19, 2006 08:33 |  #6
As far as I can tell the front focussing problem is fixed.
As far as "end-to-end sharpness", I must check ...
956 views & 0 likes for this thread, 5 members have posted to it.
2788 guests, 157 members online
