Thread started 18 Sep 2006 (Monday) 19:18
Windsurfer
mlc
Sep 18, 2006 19:18 |  #1
Well, there is a windsurfer in there somewhere - any thoughts on this image would be very welcome - I like the clarity of the water and the translucent green shadows under the boat and jetty (lost somewhat in the jpg conversion unfortunately - is there a better way to ensure more faithful reproduction at lower file sizes - this one is only just under the 100 max)
Mike
5D Mk3; 7D; 24-105 F4; 70-200 F2.8 Mk2; 300 F2.8 Mk2; 500 F4 Mk2;1.4x and 2x Mk 3 Extenders; 055CXPRO3; Benro GH2
Boxer_kidd
Sep 18, 2006 19:26 |  #2
To be quiet honest with you, It would look better if you removed the windsurfer. I could do it for you if you'd like
WWW.freewebs.com/treef​rogphotography (external link)
Canon EOS Rebel XsN Date- WoOt Film cam FOTW!
Canon A700 Digital
mlc
Sep 19, 2006 01:42 |  #3
Thanks for the thought. You are probably right - I will have a go myself on the full res version.
Having thought further on the conversion question I probably should have said what I did before asking for comments on whether there is a better way! I use Photoshop Elements and I saved the image as a jpg. In the dialog box where you set the quality I set to 5. This dialog box gives an estimate of file size which was given as 68.5. On conversion though the image was only just short of the 100. This is a consistent issue with the saved file being larger than estimated. Am I missing something?
Mike
Wildewinds
Sep 20, 2006 00:18 |  #4
I kinda like the shot. It would have been nice if the windsurfer were a bit closer. As boxer said, it's a bit too small. Also, square photos always make me think something was cropped out. That may just be my opinion, though.
I felt it was a bit flat, so I adjusted the levels a bit, added some saturation, and darkened the sky. Hope you don't mind.
- 20D - Tamron 28-75mm f/2.8 - Tokina 11-16mm f/2.8 - Canon EF 50mm f/1.4 -
mlc
Sep 20, 2006 14:30 |  #5
Thanks for the comments - I like the adjustments you have made - a definite improvement.
Mike
led ­ hed
Sep 20, 2006 14:42 |  #6
the dock takes my eye right to the windsurfer, so i like that aspect of this photo. the grren algae is kinda slimy looking.
Rob - "a photographer is a painter, in a hurry!"
Canon 7D ~ Canon EF 70-200mm f/2.8L IS MKII ~ Canon EF-S 17-55mm f/2.8 IS ~ Canon EF 50mm f/1.8 II ~ Canon 430EX ~ Canon EF 2.0X III Telephoto Extender ~ Canon SX230 HS
mlc
Sep 20, 2006 15:38 |  #7
Thanks for the comments - it was the way the dock led my eye to the windsurfer that attracted me to keeping the windsurfer in - I did consider removing it and I have sympathy with Boxer-Kidd's comments but on balance I like it in!
Mike
887 views & 0 likes for this thread, 4 members have posted to it.
Windsurfer
926 guests, 117 members online
