So enough reading at Strobist... time to test myself and see if I understood what I read.
I used a 30D in Manual mode, and a Nikon SB-26 flash mounted on a hot-shoe with pc cord attached to my camera. The hot shoe is then mounted on my old tripod and positioned at my 2:00 position.
What I want to do is take a shot of my office desk, but still keep the color of the trees outside intact, i.e. not washed out. The time is 3:00pm so it's very bright outside.
First shot, get a reading of the outside scene.
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
Next turn on the flash and see how the scene looks.
Oops... flash is too weak, bump the power up.
Now, it's too much.
After several tries, I found one I like.
Now, let's raise the tripod and point the flash 45-degree up and pull out the white card. After a few more adjustments to the power, I got this.
Looks good... but probably could use some more power...let's see what it looks like.
And there you have it... I'm really happy with this shot. The outside is exposed right, and the room is also exposed right. Well balanced...
My problem now is the LCD monitors look too dark. If I compensate for it to make it look nice, the outside gets overexposed. Any tips???
