Is there an advantage to using the 18-55mm f3.5-5.6 lens if you have the EF 28-135mm f/3.5-5.6 IS USM lens?
Other than taking off the extra weight what would be the purpose of going back to the 18-55mm?
Charles4400 Member 91 posts Joined Sep 2006 More info | Sep 19, 2006 22:47 | #1 Is there an advantage to using the 18-55mm f3.5-5.6 lens if you have the EF 28-135mm f/3.5-5.6 IS USM lens? Canon 350D/ Rebel XT
A01 Senior Member 522 posts Joined Jun 2006 Location: Sydney More info | Sep 19, 2006 23:53 | #2 The slightly wider angle? Aaron
papucla10 Senior Member 392 posts Joined Jul 2006 More info | Sep 20, 2006 00:08 | #3 Only the reach, the 18-55mm should have better IQ Canon 50D & 20D - Kodak M1033, Canon 24-105 f/4 L, Canon 28-105 f/3.5-5.6, 430EX II
Sep 20, 2006 00:15 | #4 Well yes the there would be the slighter wider angle but other than that would the 18-55 be a better lens to use for those angles compared to a longer zoom lense which encompases those angles? Canon 350D/ Rebel XT
Sep 20, 2006 00:18 | #5 What do you mean by better "IQ"? Canon 350D/ Rebel XT
JimG I feel thoroughly satisfied 12,255 posts Likes: 2 Joined Jun 2005 Location: Australia. More info | Sep 20, 2006 00:21 | #6 IQ is image quality Gear Listhttp://www.codastudios.com.au
Jettin Member 98 posts Joined Sep 2006 Location: NZ More info | Sep 20, 2006 00:22 | #7 Image Quality 5D2 l 5D l 50D l Canon 24-70mm F2.8L l Canon 135mm F2L l Sigma 50mm F1.4 l 580EX2 l 430EX
Sep 20, 2006 00:28 | #8 Thanks for clarifying that... Canon 350D/ Rebel XT
Sep 20, 2006 12:57 | #9 Is the IQ that much better on the shorter lenses (very noticable)? Canon 350D/ Rebel XT
steved110 Cream of the Crop 5,776 posts Likes: 2 Joined Dec 2005 Location: East Sussex UK More info | Sep 20, 2006 15:45 | #10 Charles4400 wrote in post #2012814 Is the IQ that much better on the shorter lenses (very noticable)? It shouldn't be a function of the zoom range, more a function of the lens itself. the 24-105 IS is supposed to be one of the sharpest going, and the 70-200 f/4 or f/2.8 lenses are so sharp you could cut yourself. Canon 6D
Sep 20, 2006 21:08 | #11 Thanks for the explanation and input Steve..this all helps out alot! Canon 350D/ Rebel XT
mfunnell Senior Member 375 posts Likes: 11 Joined Jul 2005 Location: Sydney, Australia More info | Sep 20, 2006 22:15 | #12 A01 wrote in post #2010840 The slightly wider angle? Well, I'd say the considerably wider angle. Equiv to roughly 29mm vs 45mm in 35mm FOV terms. That's a difference between actually wide and roughly normal. As to IQ, I've always found the IQ from the 28-135 to be better where the ranges overlap - but I suspect I have a better-than-average copy of the 28-135 and an at-best-average 18-55. These days I hardly ever shoot either of them, but each has enough advantages that I'll keep'em for those circumstances where they'll be useful. Some digital cameras, some film cameras, some lenses & other kit.
| Latest registered member was a spammer, and banned as such! 2694 guests, 166 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
