Thread started 20 Sep 2006 (Wednesday) 05:01
Problem with 400D?
sans2012
Sep 20, 2006 05:01 |  #1
Hi guys, my first post here and it has to be about a problem
My 400D and possibly the 75-300mm kit lens that came with it are acting up.
Had the kit for just over a week and in the last two days I have found a problem with the images. There are lines/banding in the blurry sections of my images. I did try the 18-55mm kit and the problem doesn’t seem to exist with that lens. Although the lighting for comparison was totally different. I will perform some more comparison shots tomorrow.
For now though, I'm wondering if anyone here has seen or had a problem like or similar to this.
Some example shots:
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i4.photobucket.​com …012/Mag-example-small.jpg (external link)
http://i4.photobucket.​com …/sans2012/Emu-banding.jpg (external link)
Canon 400D bla, bla...
kfahn
Sep 20, 2006 07:53 |  #2
you might want to specify more clearly which 75-300mm lens that you are using, since there is no Canon bundled 75-300mm kit lens. It may have been a "kit" from where you bought it, but without knowing what particular lens it is we can't help
jfrancho
Sep 20, 2006 07:57 |  #3
It's called "bad bokeh."
sandro9mm
Sep 20, 2006 08:00 |  #4
cheapo lens and its horrible bokeh :) its not ur camera :P
Photography Tips (external link) - Learn photography now!
Famous photographers (external link) - Video Interviews, photos, biography
My gear (external link)
Keith ­ R
Sep 20, 2006 08:20 |  #5
Take the UV filter off...
(Trust me!)
cdifoto
Don't get pissy with me
Sep 20, 2006 08:21 |  #6
UV filter has nothing to do with it. That's just ugly bokeh as stated. It's a lens thing, not a camera thing. Most (but not all!) lenses do better. :)
Keith ­ R
Sep 20, 2006 08:39 |  #7
OK, we'll see.
There are a plethora of identical threads and photos on www.birdforum.net (external link) - including one started by me a year ago - and every single time the explanation was a UV filter.
Other sites carry the same sort of thing on a fairly regular basis, and - again - it's invariably down to inexpensive UV filters.
So that's where my money's staying, unless the OP actually tells us he isn't using a filter.
cdifoto
Sep 20, 2006 08:42 |  #8
Keith R wrote in post #2011898 (external link)
OK, we'll see.
On second look you could actually be right. The "bokeh" changes direction...so it may well be a filter. Puzzling though is that it doesn't seem to affect the subject itself....
jfrancho
Sep 20, 2006 08:53 |  #9
I think the operative word is "cheapo." As in take that cheapo UV filter off. I've never had a problem with quality UV filters, though I rarely use them.
sans2012
Sep 20, 2006 09:00 as a reply to  @ cdifoto's post |  #10
@kfahn, the lens is part of the twin kit lens; standard here in Aus. It’s printed on the side of the box, the original Canon box/packaging.
The lens is an "EF 75-300mm f/4-5.6 III" Hope this can help:)
@jfrancho, NS!
@sandro9mm, yeah thanks;p
@Keith R, I took sample shots with & without the UV filter revealing the exact same problem. Cheers:)
@cdi-ink.com, a cheap lens maybe, but it performed fine up until two days ago;) And yes it is puzzling how it doesn’t affect the subject. That’s why I think it’s not as simple as a filter.
I'm going to contact Canon tomorrow and see if they can shed any light on the matter. Other than that I will see if the store of purchase will do a replacement. As I mentioned, this lens was working fine up until two days ago. Don’t make me have to prove it to you guys lol.
Before I do go into the shop though, I want to take some comparison shots using both the lenses to see if I can pinpoint the 300mm as being the problem.
Either way I'll let you guys know how I go:)
Cheers!
Michael.
sans2012
Sep 20, 2006 09:03 as a reply to  @ sans2012's post |  #11
@jfrancho, why the hell would you go assuming that I have a "cheapo" UV filter?
Cheers
jfrancho
Sep 20, 2006 09:09 |  #12
I didn't. I was responding to the information that Kieth R posted. The only thing I said about your problem was that it was bad bokeh.
sans2012
Sep 20, 2006 09:11 as a reply to  @ sans2012's post |  #13
Here is a shot I took the day after purchase, using the same lens at the same focal length as the original samples.
See, it’s not that bad…tho:)
Michael.
http://i4.photobucket.​com …ns2012/Head-Shot-Full.jpg (external link)
sans2012
Sep 20, 2006 09:15 as a reply to  @ sans2012's post |  #14
@jfrancho, I paid a good $20 au for that top of the line UV filter :p
jfrancho
Sep 20, 2006 09:21 |  #15
Yes, that's good bokeh in that older picture. Throw out you're UV. The background is much less detailed and further away in that picture, also it looks like it was shot at a lower ISO setting. Higher ISO, cluttered background, lens not known for it's bokeh, and the unknown UV "quality factor" all contribute to the differences. On top of it, the last picture looks like focus was dead on. The two above look like misses. I'm gonna stick my neck out here and say it boibls down to skill and a limitation of the equipment. Post a new example similar to the picture you just posted. What I mean is, rather than trying to recreate the issue, recreate the non issue. If you still have the banding, then you have an issue, if not, it's a limitation of the equipment. Does that make sense?
12,162 views & 0 likes for this thread
Problem with 400D?
Latest registered member is quadrentau
1927 guests, 307 members online
