Thread started 18 Dec 2003 (Thursday) 00:55
D30 +1.4 Extender +100-400mm = Won't Autofocus
gthorn
Joined Jun 2002
Dec 18, 2003 00:55 |  #1
Has anyone else tried a D30 + 1.4x Extender II + 100-400mmIS lens combination ? I have this and the camera won't autofocus at all and I can't find any information that says it should or shouldn't.
I'm no expert at these things, but I can't understand why the camera won't autofocus. Any opinios will be appreciated.
Graham Horn
vvizard
Joined Sep 2003
Dec 18, 2003 02:32 |  #2
What aperture is that lens? You'll loose one fstop from the 1.4x converter I think. That means that if your lens is a f/4, it will act as a f/5.6 with the 1.4x converter. f/5.6 is also the "slowest" the cam can autofocus, so if the aperture of the lens is slower than f/4 it's very normal that it won't autofocus.
Correct me if I'm wrong about the numbers now.
There is though a trick I've read, to tape over three of the pins on the converter, but I don't own the converter myself, and don't know if it actually works (or is safe for that matter).
RichardtheSane
Joined Jun 2003
Dec 18, 2003 02:38 |  #3
The 100-400 is F4.5-5.6, so the problem is because with the 1.4x a convertor it is making it an effective F8, which is too slow to autofocus on the D30.
A Viz said, do a search for information about taping the contacts, and you should get AF, even though it may not perform as well as without the convertor. :D
If in doubt, I shut up...
Gear: 40D, 12-24mm AT-X Pro, 17-85mm, Sigma 150mm Macro Sigma 100-300 F4, 550EX, other stuff that probably helps me on my way.
defordphoto
MKIII Aficionado
Joined Oct 2002
Dec 18, 2003 05:22 |  #4
I have that combo (rarely use it as the 1.4 is really for the 70-200) and the lens acts freaking weird with the contacts taped. I wouldn't suggest it.
defordphoto | Celebrating the art of photography®
SD500, 10D, 20D, 30D, 5D, 1DMKII, 1DMKIII
www.ussbaracing.com (external link) | www.rfmsports.com (external link) | www.nwfjcc.com (external link)
An austere and pleasant poetry of the real. Ansel Adams
chris ­ maddock
Joined Mar 2002
Dec 18, 2003 07:13 |  #5
Yeah, it's not brilliant with the D30 - needs good light and a contrasty area of the subject to have much success.
It works great on the 10D though in all but poor light IME - one of my main reasons for getting the 10D was the AF improvement.
KRs
Chris
Chris Maddock
Southampton, UK
http://www.dslr.co.uk (external link)
defordphoto
MKIII Aficionado
Joined Oct 2002
Dec 18, 2003 07:38 |  #6
It's definitely a daylight lens, but surprisingly high-rated for being one of the cheaper, long L's. I have the 70-200 for low-light stuff.
5,326 views & 0 likes for this thread, 5 members have posted to it.
1240 guests, 137 members online
