Thread started 20 Sep 2006 (Wednesday) 21:49
Lightspere 2 vs. Demb Flip-it
jcpoulin
Sep 20, 2006 21:49 |  #1
Does anyone have significant experience with these flash diffusers. I have the lightspere 2 and it was O.K.. Was not impressed with fill flash outside. Just bought the Flip-it w. diffuser as it made more "sense" to me ( at least in the manor of directing light). Can anyone share there experiences? I have the EX 580.
1DX , 7D,16-35, 24-70 2.8II, 2.8L II, , 70-200 f2.8LII IS, 300 f2.8L IS, 500 f4 IS, 100-400L, Canon 100 2.8 macro, Canon 1.4X, 580ex, AB800X4
Canon CPS Member, PPA
www.capturingtimephoto​graphy.net (external link)
SkipD
Joined Dec 2002
Sep 20, 2006 22:11 |  #2
JC, none of the "tupperware" diffusers are worth using outside of a room with nearby white walls and/or ceiling to reflect light back towards the subject. Outdoors, all they actually wind up doing for you is wasting light energy from a flash unit that is already probably underpowered for outdoor use.
The plastic diffusers generally do not present a significantly larger "source" size to the subject, so they don't do much differently from a bare flash in a direct lighting (non-reflecting) situation.
My favorite accessory for a hotshoe flash is the LumiQuest Promax System. This package, stored in a nice flat "wallet", allows for quite a few different configurations to match the conditions. It can be a partial reflector with light bouncing off the ceiling, a full reflector with white or colored (silver or gold) reflector panels, or a mini-softbox. Here's a link to their web catalog page: http://www.lumiquest.c​om/lq931.htm (external link)
Skip Douglas
Curtis ­ N
Master Flasher
Sep 20, 2006 22:50 |  #3
Well, since you own both units, you can certainly experiment with both and come to your own conclusions. I agree that the flip-it makes more sense, but I don't own either unit.
Neither one will do you any good outdoors for fill.
johneric8
Dec 03, 2006 12:08 |  #4
SkipD wrote in post #2015216 (external link)
I disagree with skip.. I use the clear lightspere outside in all occasions and it's fantastic.. The coverage is even and the quality of ligh is amazing...
Too much Gear to list! :lol:
Headcase650
Joined Jun 2004
Dec 03, 2006 14:10 |  #5
The lightsphere does indeed waste alot of light but anything that makes the light sourse bigger will soften shadows so I wouldnt call it useless outdoors. Ive used it outside with the top on and pointing at the subject for direct flash and you can see a difference if you take 2 same shots one with and one without.
60D, Canon 18-135 IS, Sigma 10-20 hsm, 24-70 2.8 hsm, 70-200 2.8 hsm, 430EX II, and all the other stuff that goes along with it.
NickSim87
Sir Chimp-a-lot
Dec 03, 2006 21:00 |  #6
I also bounce outside, it's useful when you want to duffuse and soften the fill light when you are shooting at sunrise/sunset which is also very soft light.
Gear List | Feedback
bluej511
Dec 03, 2006 21:13 |  #7
so would you guys say the Lightsphere from Gary Fong is the best diffuser? i saw his site and it looks very darn interesting and very very functional
Minolta Maxxum STsi w/ 28-80mm kit lens & Tamron 80-210 f/4.5-5.6.
"The beautiful thing about photography is what kind of work people do full time, could be anything from a garbage man to a scientist."-Vicken B
"No matter what happens in the world, a photographer will always be there."-Vicken B
Curtis ­ N
Master Flasher
Dec 03, 2006 21:26 |  #8
bluej511 wrote in post #2349832 (external link)
People tend to have strong opinions on flash modifiers. There are some who think Fong is a genius and some (perhaps more) who think he has done an excellent job marketing an overpriced piece of plastic with little functionality.
In any event, I would not buy anything based on its own advertising hype.
There is nothing magical about flash attachments. The simply redirect some or all of the photons coming out of the flash. The key to good lighting is to first figure out where you want those photons to go, and then determine the best device to get them there.
I use flash a lot, and I have never felt the need for a $50 piece of translucent plastic to make the light go where I wanted.
bluej511
Dec 03, 2006 21:29 |  #9
so what do you use curtis? im sure mine will only be fill flash and some night photography
JMHPhotography
Dec 03, 2006 21:39 |  #10
To be quite honest... I find that I get the best results using an unmodified flash outdoors for fill light. The key to fill light is you do NOT use flash for the main light so whatever modifier you decide to use wouldn't really matter. You're getting your primary lighting from the sun or reflector/diffusion panel and the flash is only filling in shadows, right? If you do this properly, you shouldn't even be able to tell that flash was ever used.
~John
(aka forkball)
Have a peek into my Gearbag. and My flickr (external link)
editing of my photos by permission only. Thanks
Headcase650
Joined Jun 2004
Dec 03, 2006 21:40 |  #11
If you want to try a good modifier that will only cost you a couple bucks check this out. It works as well as the lightsphere, maybe even better in every way except direct outdoor use.
http://www.abetterboun​cecard.com/ (external link)
Stop by walmart craft section and pick up a couple Foamies 9x12" white sheets and try to find the largest diameter bicycle inner tube you can find for a couple bucks. Cut the foam sheet as described in the video and then cut a 1 1/4 section out of the inner tube for the attachment band and your all set.
Curtis ­ N
Master Flasher
Dec 03, 2006 22:02 |  #12
bluej511 wrote in post #2349891 (external link)
Outdoors for fill, it's direct flash. Forkball is right on the money here. Besides, when you're competing with the sun you need all the power you can get, and diffusers rob power.
Indoors with low ceilings, you have a plethora of economical choices. The usual idea is to throw most of the light against the ceiling to light up the general area while directing a little forward to brighten up your subject and fill shadows. I generally recommend the index card & rubber band approach, though my flash units are encircled with velcro so I have a homemade piece of white plastic with a velcro strip that I use. Recently I was using a new flash unit (no velcro) and I stuck a white Post-It note to the back side. Worked great at close range.
If you're in a room with high ceiling or outdoors at night, the only way to improve the light is to make the light source bigger. The Lumiquest Pocket Bouncer fits this bill (I use the Promax System with white insert, which is basically the same thing).
ChrisBlaze
Dec 10, 2006 04:32 |  #13
can some one post pics with and without the lightsphere?
Canon 1D Mark II N/5D Mark III/ 6D/ 7D /85mm f1.2L Mk1/ 24-70 f2.8L/ 70-200mm f2.8L IS USM/ 100mm Macro f/2.8
Honolulu POTN
jimlp
Joined Sep 2004
Dec 10, 2006 10:22 |  #14
ChrisBlaze wrote in post #2379540 (external link)
This was my first test with my Lightsphere. The walls and ceiling were painted different colors so I had a little trouble with color balance, I feel the lighting is as advertised. I have never gotten results like this with bounce flash or any other diffuser, the fact that this is my first time using the system speaks for it's ease of use. The system was worth the money to me, it may not be to you. Different strokes.
Canon 1DsMk2, EOS RP, Canon 17-40 f4L, 24-105 f4.0L ll, Canon 70-300 f5.6L IS , Sigma 85mm f1.4
Balliolman
Dec 10, 2006 10:28 |  #15
I'd like a Lightsphere and Jimlp's photo confirms that. Flash is a bit of mysterious art to me and Fong's device seems to make it all less hit and miss. The problem is Lightsphere's seem to double in price as they arrive in Britain ... :-(
Balliolman
Stereoshooter
http://www.flickr.com/​photos/balliolman/ (external link)
Want to know more? Q. & A. with Balliolman: 3D/Stereo Photography https://photography-on-the.net/forum/showthre​ad.php?t=150661
DReb; Canon 50 f1.8; Canon 28-135 IS; Loreo LIAC(T); Flashtrax; Canon 17-40 L; Manfrotto 055 PRO B tripod; Canon 28mm 2.8; Whibal
Need: Primes; Would like: Canon 5D;
12,469 views & 0 likes for this thread, 14 members have posted to it.
2681 guests, 162 members online
