Thread started 22 Sep 2006 (Friday) 11:14
Sharper Picture stopped down?
HughScot
Sep 22, 2006 11:14 |  #1
Is is true that if you have an f2.8 lens and you stop it down to say f4 the picture will be sharper? To me it does not sound correct but I've read it a couple of places and perhaps misunderstood the writers.
Hugh
Hugh
Canon 40D, EF 24-105mm f4L IS, EF 35-135, EF 70-200 f2.8L IS, EF-S 10-22, EF 100mm f2.8 macro, Sigma 18-200 OS.
runninmann
what the heck do I know?
Gallery: 47 photos
Joined Feb 2006
Sep 22, 2006 11:18 |  #2
Yes. Most lenses have a "sweet spot" that is a couple of stops down from wide open.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Sep 22, 2006 11:19 |  #3
All lenses are a bit softer wide open. They're also usually a bit softer at f/16-f/22 due to diffraction.
Bob
kevin_c
Sep 22, 2006 11:20 |  #4
Yes, as runninmann said - usually stopping down by about 2 stops will be about the 'sweetest' spot on most lenses.
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
ChopstickHero
Sep 22, 2006 11:21 |  #5
i find my 17-55 very sharp at f3.2! but yes, stopping it down will help.
Canon 40D and 350D :: Canon 70-200mm f/2.8L IS :: Canon 17-55mm f/2.8 IS :: Canon 10-22mm f/3.5-4.5 :: Canon BG-E2 & BG-E3 :: Canon 430EX Speedlite :: Crumpler 6MDH & The Whickey and Cox
HughScot
Sep 22, 2006 11:25 as a reply to  @ Bob_A's post |  #6
"Wish List: Enough talent that it matters which lenses I use."
That truly is an excellent point. I have been contemplating either a Canon 70-200mm f2.8L IS or the brand new 70-200 f4.0L IS. The f2.8 is very heavy at 3.5 lbs as well as expensive. I'm trying not to let price be a factor.
Hugh
kevin_c
Sep 22, 2006 11:27 |  #7
Sigma 70-200 f/2.8 ?
-- K e v i n --
runninmann
Gallery: 47 photos
Joined Feb 2006
Sep 22, 2006 11:33 |  #8
HughScot wrote in post #2022056 (external link)
As an amateur SLR photographer for almost 30 years, I've never been totally satisfied with any of my pictures. There's always something in the composition or the exposure or (back in the film days) the processing that left me wanting. So, my wish list is to be in a position to say, "Man, I nailed it. If only I had the ??? lens, it would have been perfect.
Wilt
Sep 22, 2006 11:48 |  #9
Hugh, you have read the 'truth' about lenses generally performing best about 2-3 f/stop from the widest aperture. Another point I will add, however, is that a truly good lenses will perform even wide open at levels which often exceed the best that a mediocre lens can do stopped down 2-3 f/stops!
For example the Canon 70-200 vs. the Canon 18-55 (yes, it is a bit unfair to compare different lenses of focal length ranges but...)
The 70-200 when wide open has MTF ratings at 70mm of 1952 center, 1880 edge
The 18-55 when stopped down has MTF rating at 55mm of 1719 center, 1417. In other words the 18-55 at its best is worse than the 70-200 at its worst!
englishw
Sep 22, 2006 11:57 |  #10
My 70-200 f/2.8L IS and 17-40 f/4L both are "sharpest" at F8...
-BilL
www.OurAlbumOnline.com (external link)
All Canon
: EOS 30D w/ BG-E2 grip
| A2E | 50mm f/1.8 | 17-40mm f/4L | 70-200mm f/2.8L IS | Speedlite 430ex | 2x II Extender EF | 500D Close-up Lens | RS-80N3 Remote Switch
calicokat
Sep 22, 2006 12:36 |  #11
I believe all lenses are sharp as can be at F/8 or so
"You are going to fall off a cliff trying to get a better shot someday"- My hopeful and loving wife :eek: :twisted:
My Website (external link)
Calicokat 1990-2007 RIP My Loving Kitty
Wilt
Sep 22, 2006 14:12 |  #12
calicokat wrote in post #2022310 (external link)
Not always! The infamous kit lens performs best at f/5.6 at the short end and middle of the focal length ranges, and at f/11 at the long end or its range!
calicokat
Sep 22, 2006 14:17 |  #13
I stand corrected :)
Wilt
Sep 22, 2006 14:20 |  #14
calicokat wrote in post #2022661 (external link)
I think a good generality is that most lenses perform quite well at f/5.6 and f/8. It's 'best' performance may actually be at another f/stop, but you cannot go wrong cranking in f/5.6 or f/8!
calicokat
Sep 22, 2006 14:43 |  #15
But my 85L is sharp as a tack at F/2.8 :eek: j/k don't want to get anyone too excited
1,777 views & 0 likes for this thread, 9 members have posted to it.
2856 guests, 167 members online
