Thread started 22 Sep 2006 (Friday) 20:53
The dumbest question but please help me.
nickybegood1998
Sep 22, 2006 20:53 |  #1
I have the Canon Rebel XT and I just ordered and received the Tamron SP AF28-75mm F/2.8 XR Di LD Aspherical (IF) Macro lens. The box says that it's for the Canon-AF. Is this lens compatible with my camera? I thought I had done lots of research but when I got the lens today and started taking test shots, they were horrible. Not a focused one in the bunch. That got me wondering if I had the right lens for my camera.
Please someone help me out here.
Thanks,
Karman
7D Gripped, 30D Gripped, G10 | Tamron 28-75 2.8 | Canon EF 50 1.4 USM, 85 1.8 USM, 28-135 IS |Sigma 70-200 f/2.8 | Canon 430EX | Lowepro 300 AW & Toploader 75 AW | Sigma 1.4 TC
ccheever
Sep 22, 2006 21:21 |  #2
if it mounts on the camera i would suspect it is the correct one.
30D & 5D MKII | BG-E2 | 10-22mm | 28mm 2.8 | 50mm 1.4 | 85mm 1.8 | 420 EX | Photogenic Studiomax III | Bogen 3001N & 804RC2
www.ChrisCheever.com (external link)
Fureinku
Sep 22, 2006 21:22 |  #3
well, make sure you arent on manual focus, make sure the switch to macro/normal is in the correct position for your focal distance, could you post a picture so we could try to help you further? www.imageshack.us (external link)
What mode are you shooting in? proper shutter speed to aviod camera shake? etc etc...
And yes, thats a correct lens for your camera
Gear List | Wish List |
newfly5
Joined Nov 2005
Sep 22, 2006 21:38 |  #4
I use that lens on that camera and love it. Now lets figure out the human error thats happening. keep us posted
Ben
30D 17-552.8 is 50 1.4, 80 1.8, 28 1.8,tammy 28-75, 17-40L, 70-200L 2.8,10-22 canon, 24-105L, rebel xt, AB strobes
nickybegood1998
Sep 22, 2006 21:42 |  #5
Ok, here is one of the pics that I took tonight. Keep in mind that I'm just learning. My settings were:
Shooting mode: AV
SS 1/30
Aperture value: 3.5
ISO 200
Focal Length: 75mm
Please help me. Thanks.
lostdoggy
King Duffus
Joined Aug 2004
Sep 22, 2006 21:43 |  #6
If you half press the shutter or pressing * button depending on your setup will bring the subject into focus and if you move to another subject much further or closure and press the button the camera should refocus. If not make sure the lens is in AF not MF. If it is in AF mode then remove lens and re-install lens and check again. Otherwise you might have a bad lens.
lostdoggy
King Duffus
Joined Aug 2004
Sep 22, 2006 21:46 |  #7
nickybegood1998 wrote in post #2024126 (external link)
Shooting mode: AV
SS 1/30
Aperture value: 3.5
ISO 200
Focal Length: 75mm
[/IMG]
That is not out of focus. You just discover Bokeh. W/ such a large aperature you'll need to be more carefull as to where you want to be in focus because it will have a very shallow DOF.
nickybegood1998
Sep 22, 2006 21:47 |  #8
I checked and I am in AF mode. I use the back button for focusing. I'm pressing the back button to focus and pressing the shutter release to take the picture.
I will remove the lens and put it back on. I only have 7 days to figure out if it's bad or not so I'm trying to work swiftly.
Thank you so much.
Billginthekeys
Billy the kid
Joined Nov 2005
Sep 22, 2006 21:49 |  #9
Shooting mode: AV
SS 1/30
Aperture value: 3.5
ISO 200
Focal Length: 75mm
| Content warning: NOT AN IMAGE
it doesnt look that bad to me. BUT, in the case of this picture, it would most likely be camera shake. you are at 75mm but only using 1/30th shutter speed. it probably would have come out better if you had used f2.8, and mabye bumped the ISO up and gotten the shutter speed around 1/100th. Have you tried the lens in more controlled conditions (on a tripod, various settings, ect..)?
Mr. the Kid.
Go Canes!
My Gallery (external link)My Gear
what the L. just go for it.
lostdoggy
King Duffus
Joined Aug 2004
Sep 22, 2006 21:49 |  #10
Try this exercise, set the camera to center point focus. This where only the center red light will appear when you are focusing. Aim the center point at the subjects eye and depress the shutter button half way and hold. Reframe the shot to your liking while holding the shutter button halfway (focus lock) and depress the button all the way. Be gentle when depressing the button otherwise you'll get camera shake (blurr)
nickybegood1998
Sep 22, 2006 21:49 |  #11
When I crop in at 100%, everything is fuzzy. Am I expecting too much? I see other shots with this lens and I just imagine what mine might look like. So you think the photo is in focus? I locked on the eyes but you would never know it by looking at this photo.
lostdoggy
King Duffus
Joined Aug 2004
Sep 22, 2006 21:58 |  #12
Raise your ISO so that your shutter speed is higher as Bill recommend. You need at least 1/focal length shutter speed so try 1/125 to be on the safe side. Brace your on something solid depress the shutter button smoothly so you're not jerking the camera. Left hand holding the lens and right hand holding the camera. Elbows tuck in not sticking out. left foot foward and slightly bend. Hold your breath when you are ready to depress the shutter button. These are some suggestion to prevent camera blurr.
lostdoggy
King Duffus
Joined Aug 2004
Sep 22, 2006 21:59 |  #13
One more thing set the camera to the best/highest quality setting.
crn3371
Sep 22, 2006 22:01 |  #14
For that shutter speed, at 75mm, it looks pretty good to me. You're pushing the envelope for a sharp handheld shot. I'd say the focus looks ok, probably just a little camera shake giving you the impression that it's out of focus.
nickybegood1998
Sep 22, 2006 22:07 |  #15
Ok, this isn't much better. Sorry the subject isn't good...kids aren't cooperating anymore. I selected the center focus point and focused on the eye. I'm also set on the best quality setting. The ISO is probably too high but I would think I would still get a good image but with more noise right? I focused on the eye but why is the mouth in better focus?
TV
SS 1/100
Aperture 2.8
ISO 800
focal length 32.0
It's pretty pathetic right? I just want to get one good shot so I can feel good about the lens. My subjects are falling asleep on me so I will have to switch to something else (smile).
1,563 views & 0 likes for this thread, 8 members have posted to it.
2858 guests, 168 members online
