Thread started 23 Sep 2006 (Saturday) 06:51
UV Filter Function
mukund2
Sep 23, 2006 06:51 |  #1
Is UV filter in front of the lens really improves sharpness, exposure & contrast of the image?
Regards,
Mukund
René ­ Damkot
Sep 23, 2006 06:57 |  #2
Maybe in very specific circumstances. It can also reduce IQ in other specific circumstances. I don't use 'em.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
molesrkool
Sep 23, 2006 07:10 |  #3
if i dont have a hood.. ill put on a uv or cp depending on the lens
Canon EOS 350D / Canon EOS 100
Canon EF 70-200 F/4 L USM
[COLOR=black]Canon EF 100 F/2.8 Macro USM
LOOKING FOR A CANON EOS 20D $650-$700
René ­ Damkot
Sep 23, 2006 07:15 |  #4
Tip: Buy a hood ;)
SkipD
Joined Dec 2002
Sep 23, 2006 08:01 |  #5
mukund2 wrote in post #2025437 (external link)
My understanding is that the glass in today's lenses is designed to filter out UV, and for sure there is a filter in front of digital sensors that does that. Adding a UV filter to the front of a lens is not likely to noticeably reduce the UV getting to the digital sensor any more than the built-in filtering does. Thus you are not likely to see any improvement in image quality by adding a UV filter.
A lot of folks have been convinced that they need to add a filter to the lens for "protection" of the lens. Adding glass surfaces in front of a lens will definitely add to the risk of image degradation, depending on the light sources that can impinge on the filter. Read this article for more information: http://www.luminous-landscape.com/columns/​sm-feb-05.shtml (external link)
What will definitely tend to help image quality is to use a properly designed lens hood on every lens you have. They block stray sources of light that would tend to degrade the image.
Properly designed lens hoods (rigid as opposed to collapsible rubber types) also offer quite a bit of physical protection for the lens. They will help you keep your fingers off the glass, and they provide a lot of crash protection as well.
If you do choose to use a UV filter all the time, make sure it is the highest quality multicoated filter that you can buy to reduce the liklihood of image degradation.
Skip Douglas
Double ­ Negative
*sniffles*
Sep 23, 2006 08:44 |  #6
A UV filter does two things;
1) Attenuates light in the ultraviolet range of the spectrum. This occurs typically at high altitudes, at the beach and far off under hazy conditions. While the UV filter helps, it's not a magic bullet.
2) It protects the front of your lens (arguably).
It doesn't really improve sharpness and contrast except in case #1 above and in a limited way. It doesn't do anything for exposure.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Sep 23, 2006 08:47 |  #7
It's a lens condom
Gallery: http://tomyi.smugmug.c​om/ (external link)
1,117 views & 0 likes for this thread, 6 members have posted to it.
UV Filter Function
2858 guests, 168 members online
