Thread started 25 Sep 2006 (Monday) 21:02
Why a wider aperture make the camera heavier
BradT0517
I almost caught fire
Sep 25, 2006 21:02 |  #1
Ok so I have been reading through threads where people say what <edit>lens</edit> they want. Then some one comments back saying it would weigh to much why is this.
My Website (external link)
tsaraleksi
Sep 25, 2006 21:08 |  #2
Because to let in more light requires a bigger opening. Therefore, it requires more glass and more lens body. This is especially true as lenses get longer, because you need a bigger opening to let in the same amount of light as with a wide angle lens. Also, having a lens with a constant aperture over a zoom range requires it to be bigger, because it can't narrow as it zooms like one with a variable apeture.
--Alex Editorial Portfolio (external link)
|| Elan 7ne+BG ||5D mk. II ||1D mk. II N || EF 17-40 F4L ||EF 24-70 F2.8L||EF 35 1.4L || EF 85 1.2L ||EF 70-200 2.8L|| EF 300 4L IS[on loan]| |Speedlite 580EX || Nikon Coolscan IV ED||
BradT0517
Sep 25, 2006 21:10 |  #3
ok that makes sense
yonni
Gallery: 19 photos
Sep 25, 2006 21:12 |  #4
I think you maybe referring to the lenses instead of the cameras. For example, the 70-200 f2.8is weighs 3.2lbs vs. the f4 version which weighs less that half that. Much more glass used in the f2.8. Hope this helps.:)
John
5Dc. 40D 400 5.6, 300 f4 is, 200, 135, 35, 17-40, 24-105, 70-200 f4is Ls
lensview
Sep 25, 2006 21:15 as a reply to  @ tsaraleksi's post |  #5
That's very simple.....the widest aperture rated cameras are 1 Series. They are naturally the heaviest. The reason for that is because they have a heavy duty lens mount. Therefore, you can mount a wide aperture lens on them without starting to bend the focal plane. Otherwise that would ruin many pictures taken with very wide apertures where focal plane is very thin and fragile....i.e., it can get easily deformed.
Canon SD600
Sandisk 1Mb ExtraIII SD card
tsaraleksi
Sep 25, 2006 21:17 |  #6
lensview wrote in post #2037619 (external link)
My head is spinning; please please tell me you aren't serious.
lensview
Sep 25, 2006 21:22 |  #7
tsaraleksi wrote in post #2037623 (external link)
Alexander, I am deadly serious.
BTW, you a Tsarist or a Trotskist ?
Canon SD600
tsaraleksi
Sep 25, 2006 21:24 |  #8
lensview wrote in post #2037644 (external link)
Russian student :) . And it's just Alex, my parents didn't want me shortening my name my whole life... so I think I'll switch to Al, out of spite :D .
Sir ­ Tony
Sep 25, 2006 21:25 |  #9
Huh......???? No.
Canon EOS 30D and EOS 3 (35mm Film)
Canon 24-70mm f/2.8L
Cambo SC w/ 150mm Caltar II-N f/5.6 (4x5)
http://www.flickr.com/​photos/61776846@N00/ (external link)
lensview
Sep 25, 2006 21:26 |  #10
tsaraleksi wrote in post #2037650 (external link)
Good thinking......Al is so close to A1........I am sure you'll be very big at your school with all female students.
Canon SD600
Double ­ Negative
*sniffles*
Sep 25, 2006 21:30 |  #11
The sensor lubricant is a thicker viscosity, also.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
lensview
Sep 25, 2006 21:36 |  #12
Double Negative wrote in post #2037679 (external link)
Naturally, otherwise you'd get the mirror slapping itself silly all the time because of lubricant thinning which would be caused by higher heat influx thru wider apertures.
Yes, that's a rather elementary fluid mechanics consideration, yet you have observed it very aptly.
Canon SD600
Mark_Cohran
Joined Jul 2002
Sep 25, 2006 22:06 |  #13
Hmmm, and I thought the extra weight was due to the internal cooling system and the quantum particle trap.
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
lensview
Sep 25, 2006 22:08 |  #14
Mark_Cohran wrote in post #2037829 (external link)
Mark
Now, I am getting all goose bumpy....this is starting to sound exactly like the FM Canon Gear Forum !:lol: :lol: :lol:
Canon SD600
Double ­ Negative
*sniffles*
Sep 25, 2006 23:47 |  #15
The 1.3 jigawatt flux capacitor is what cleans up the temporal noise though.
1,953 views & 0 likes for this thread, 7 members have posted to it.
2826 guests, 158 members online
