Hello,
I'm just wondering any pros do Real Estate photography? Is wide angle the way to go? Logically it should be yes? how about Speedlites? Or do you base solely on ambient lighting?
thanks.
delhi Goldmember 2,483 posts Likes: 1 Joined Feb 2005 Location: 3rd Rock from the Sun More info | Sep 27, 2006 00:07 | #1 Hello, Vancouver Portrait Photographer
MHP Senior Member 649 posts Likes: 1 Joined Aug 2006 Location: Taranaki, Aotearoa More info | Sep 27, 2006 00:29 | #2 real estate photography requires nice bright interiors balanced with exterior light. so use as much flash/light as you can get, obviously don't over do it though and use it creatively. you got an xt, so a zoom with 17mm minimum at your widest length should be surfice, although wider helps. you need from wide through to 300mm for views etc. Mark
MHP Senior Member 649 posts Likes: 1 Joined Aug 2006 Location: Taranaki, Aotearoa More info | Sep 27, 2006 00:35 | #3 |
jameslcross Member 223 posts Joined Sep 2006 Location: Norwich, UK........ Current best leg: Right Likes: Lost. Licks:Stamps. More info | Sep 27, 2006 03:50 | #4 Nice shot mark! "Insanity: doing the same thing over and over again and expecting different results."
MHP Senior Member 649 posts Likes: 1 Joined Aug 2006 Location: Taranaki, Aotearoa More info | Sep 27, 2006 14:15 | #5 |
chtgrubbs Goldmember 1,675 posts Joined Jul 2003 More info | Sep 27, 2006 15:08 | #6 If you are using a camera with a 1.6 mag factor, then I would want at least a 12mm wide lens, or 20mm for full-frame. Even wider might be useful if you need to photograph small rooms such as bathrooms.
Lestat Mostly Lurking 16 posts Joined Sep 2006 Location: Sydney, Australia More info | Oct 27, 2006 02:11 | #7 Sigma 10-20, Speedlight 580ex This is the way the world ends,This is the way the world ends,This is the way the world ends, Not with a bang but a whimper.
coreypolis Cream of the Crop 6,793 posts Likes: 4 Joined Mar 2005 Location: Mercer Island, WA More info | Oct 27, 2006 02:14 | #8 Permanent bandepends on what they want. if its a quick snap for a web page or if its a color balanced distorionless magazine image. Photographic Resources
AdamJT Senior Member 330 posts Likes: 1 Joined Oct 2006 Location: Ohio More info | Oct 27, 2006 14:45 | #9 My father-in-law is a real estate agent. He uses a 35mm lens to minimize the distortion of depth. He has had several complaints about rooms looking larger in the picture than in real life. He likes to take a few different pictures from the same spot and then stitch them together later. He has done some virtual tours this way for higher end homes. Hope this helps... Adam
coreypolis Cream of the Crop 6,793 posts Likes: 4 Joined Mar 2005 Location: Mercer Island, WA More info | Oct 27, 2006 15:00 | #10 Permanent bana pano option www.0-360.com Photographic Resources
Jon,TheElder teaching fish to ride a bicycle 2,490 posts Likes: 2 Joined Oct 2004 Location: Warren, Michigan More info | I use a Canon 17/40 for everything. A 40D, a 30D, some nice glass and a great Shooting Partner.
MoodyBlues Senior Member 373 posts Likes: 5 Joined Sep 2004 More info | Oct 30, 2006 09:13 | #12 Canon 16-35 f/2.8 works for me.
1DX / 24L II / 35L / 85L II / 100L Macro / 16-35L II / 24-70L II / 70-200L II / 1.4x III TC / 600EX-RT
| Latest registered member is Thunderstream 1187 guests, 120 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
