Ok..I did some test because I noticed that some of my images are not focusing correctly. When I use the middle AF point everything works well..focus is on the spot. But when I use the 1 o clock AF point (the one between the top and the right AF points) I get inconsistent focus.
I used a tripod for this test and focused on the left eye of the doll(your right when facing you)..here are the sample pix.
This is on spot..the face is in focus. @f2.8
But this one the face is out of focus and the foot becomes in focus, while the AF point is still on the right eye. @f2.5
I've read that this is normal for this lens and just have to accept the fact that it does this from time to time.
Should I return it and ask for another copy? or will I just get the same results?
Thanks a whole heap!
