zzpethe wrote in post #2049503
I have a Sigma 10-20mm with a circular polarizer on it. I saw a grad ND filter for sale and was wondering how it would work if I bought a adapter. Could I screw on the adapter over the polarizer or would i have to take off the polarizer?
We are traveling to New Hampshire next week and I want to take scenery shots. Would it be a good idea to buy the new filter and use it at times without the polarizer?? What would you do?
Zsolt, I've experimented a lot with the 1020EX and filters. Using a bayonet-thread-type CPF with any 10mm lens will render uneven polarization across skies. You can use it effectively though if you're careful, and the CPF can double as a 2-stop ND filter too to slow down exposures.
I find that the Lee/Cokin/HiTech set up with rectangular filters are more effective though. The P-versions won't vignette assuming you only use 1 filter and a single-slot holder (i.e., wide angle holder). I think the best filter you can use with your UWA is a rectangular 2-stop (or 3-stop) ND GRADUATED.
I'd recommend you invest in a Cokin P-style wide angle (single slot) holder for $13, a P-style 77mm adapter ring (to mount to your 1020EX), and a good quality Lee or HiTech ND Graduated filter. You can buld around this set up later on.
