johnstoy wrote in post #2054295
Take pictures of controlled action, usually with the ball on the ground...It is most desirable to show ones soccer skills as controlled and in command of the ball...
wild bouncing balls and non directional heading of the ball will look sloppy to a keen soccer eye...Good Luck
Regarding "non directional heading," ...I'm meant, heading the ball with the head, in no specific direction...Heading is infrequent ,if at all in youth soccer...however just in case...it looks mostly out of control, besides being somewhat painful...
If you are confident the 1.4 TC won't affect Image Quality, (if it's a good brand of TC it shouldn't) than it might be ok...
Test it out at the field before the game... focus on the opposite corner flag, and check your shutter speed...if the distance is satisfactory than you'll be OK...If you stand on the sideline, in the middle of the field, you might be able to catch a lot of center field action in front of you, than you wouldn't need the TC...you have a long game with lots of time to take pictures with and without the TC...
If you go over to the goal on either side and take pictures for close up action , no TC... However, if you want to capture action clear on the opposite half of the filed than you would need to put the TC on...
Walk around along the sideline and follow the ball action while taking pictures, you might have to run to get there...just don't go onto the field...
