Thread started 01 Oct 2006 (Sunday) 10:18
17-40 or 24-7???
surfologist
Oct 01, 2006 10:18 |  #1
Which one?
17-40 f/4L here it is cheap... but L and wide angle
24-70 f/2.8L, here it is faster and more reach, BUT not too wide!
All choices will be coupled with a 70-200 2.8 IS
My main use for these will be Weddings. Sometimes will travel, and use for walkaround.
Is the 24mm not wide enough for weddings?
then what about the gap between 40 and 70mm?
My! Gear! Bag!
All of my money has gone to L!!
Luckie8
Oct 01, 2006 10:46 |  #2
24mm on a crop body is not wide at all.
I would choose 17-40 then pick up a 50 prime to cover the gap from 40 to 70
Feedback
JaGWiRE
Oct 01, 2006 10:54 |  #3
Luckie8 wrote in post #2061291 (external link)
Sounds like what I'm planning to do once I get my 70-200.
Canon EOS 30D, Sigma 30 1.4, Sigma 10-20, Sigma 105 Macro, 135L, 430ex, Lowepro Mini Trekker AW, Manfrotto 3001pro w/486rc2 and 804rc2 head, Manfrotto 681 w/ 3232 head.
http://www.brianstar.s​mugmug.com (external link)
surfologist
Oct 01, 2006 10:58 |  #4
Cool... What about the 17-55?
or no...
My! Gear! Bag!
Rumjungle
Oct 01, 2006 11:00 |  #5
I agree with what Luckie8 says. 24mm (x1.6) is not quite wide enough for my tastes either. The 17-40 would be a good walk-around lens and it would also do fine at weddings if you are using flash.
Gear
stupot
Oct 01, 2006 11:08 |  #6
get the 24-70... its the perfect wedding lens. 17-40 could be too slow, and why get it when you have a 17-85 you can use for the wide shots?
Canon EOS 350D, Sigma 10-20 f4-5.6, 24-105 f4L IS, 70-200 f4L, 300 f4L IS, Kenko 1.4x pro300, 430EX, Apple Powerbook G4
Free filters for your flashgun!
cdifoto
Don't get pissy with me
Oct 01, 2006 11:10 |  #7
I'd go for 24-70 then once I had enough money, an ultrawide to really get wide.
Hey wait a minute...I did exactly that! :)
SuzyView
Oct 01, 2006 11:12 |  #8
I recommend that 24-70 for weddings because it is so handy. Some have opted for the Tamron 28-75 which is also a wonderful lens and much cheaper.
kevin_c
Oct 01, 2006 11:53 |  #9
On a crop body as the OP has, I'd hesitate recommending the 24-70, is it really wide enough?
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
Tareq
"I am very lazy, a normal consumer"
Oct 01, 2006 12:41 as a reply to  @ kevin_c's post |  #10
I have 16-35L and 24-70L, both are so fast and both are great.
I am so happy with both and i don't look back for another lenses as 17-40 or 17-55 or 24-105 as i need f2.8 or Wider always.
Good luck.
Galleries:
http://hamrani.deviant​art.com/gallery/ (external link)
Facebook (external link)
cdifoto
Oct 01, 2006 13:05 |  #11
kevin_c wrote in post #2061517 (external link)
Not for everything. But you could argue 17mm isn't wide enough either..for everything...or 40mm long enough...or 70mm long enough...
kevin_c
Oct 01, 2006 13:39 |  #12
cdi-ink.com wrote in post #2061794 (external link)
I agree totally, But the OP's only asking opinions on these two lenses and focal lengths :-)
-- K e v i n --
surfologist
Oct 01, 2006 13:44 |  #13
kevin_c wrote in post #2061937 (external link)
Its all good.... im still learning, so i am open to ANY opinions... but thanks for trying to keep it on topic...:)
My! Gear! Bag!
kevin_c
Oct 01, 2006 13:55 |  #14
:-) -Have you asked anyone in the 'weddings' forum?
They will be the 'experts' to ask about what lenses they use and why.
You really need to cover from 10 to 300mm but that is not always practical :-)
I think anything wider than 17mm on a crop body is likely to introduce severe distortion at the ends of any group shots, although I'm sure if you keep the camera level you can get away with wider.
The 24-70L is by all acounts a good lens, but I'm sure you will find it not wide enough for a lot of group shots.
You say you have (or will have?) a 70-200 so that will cover that range OK, you may have to have 2 others to cover the 10mm to 70mm range, but if I had to chose just one lens to compliment the 70-200 it would be the 17-40L although it is 'only' f/4. You mention the 17-55mm that would give you a bit more range and it's faster (and more expensive!)
You may need a 50 f/1.4 to fill the gap and this would make a great low light lens as well.
The options are quite varied I'm afraid...
-- K e v i n --
ed ­ rader
"I am not the final word"
Oct 01, 2006 13:56 |  #15
surfologist wrote in post #2061194 (external link)
Which one?
i own both and i think you should too :D .
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
1,990 views & 0 likes for this thread, 10 members have posted to it.
17-40 or 24-7???
2912 guests, 157 members online
