Thread started 02 Oct 2006 (Monday) 05:33
Photoshop actions
jameslcross
Location: Norwich, UK........ Current best leg: Right Likes: Lost. Licks:Stamps.
Oct 02, 2006 05:33 |  #1
Hi all,
Just a quicky, I was recording a few action at the weekend, all went well except for the action I was recording for converting pictures to sepia.
I recorded adding a sepia filter, then a hue saturation level with the opacity set to 46%.
Every time I play this action I get a little message saying "Photo filter not available!"
Any ideas?
Cheers
James:cool:
"Insanity: doing the same thing over and over again and expecting different results."
Albert Einstein.
R ­ Hardman
Oct 02, 2006 07:21 |  #2
I found that at least for PS5 the photo has to be set to 8 bit for the majority of the filters and other tools to work and will give an error if the photo is set for 16 bit.
"Whatever you can do to avoid Photoshop is worth it"
EOS 7D, EOS 350D, EF 17-40mm f/4L USM, EF 70-200mm f/4L USM, EF-S 18-55mm f/3.5-5.6 USM (Kit)
Rick's Digital Desert (external link)
amccomis
Oct 02, 2006 08:14 |  #3
James,
If you've got your magic settings for how you do the color, you might try adding these steps first:
1) Image Mode -> Convert to grayscale
2) Image Mode -> Set bit depth to 8 bit
3) Image Mode -> Convert to RGB
4) Do your colorization/etc.
This will take care of a source image that's not already in the right color space or bit depth.
Had gear, but sold it off. Starting back in with a SL1 / kit lens. Looking to expand the collection.
jameslcross
Oct 02, 2006 08:18 |  #4
Hmmm I'll check this out when I get home, I'm sure it was an 8 bit photo.
Amccomis, may i ask why you convert to grayscale first?
Albert Einstein.
ssim
Joined Apr 2003
Oct 02, 2006 08:38 as a reply to  @ jameslcross's post |  #5
I've had that same response in photoshop a number of times. Sometimes it is fliter not available or sometimes it is "command xxxx not available". It drives me crazy and have not been able to find the solution. Everywhere I have posted this question I get the answer "well it should work". Yeah, ok but it doesn't. I've even contacted the the author of the actions that I have downloaded and they say it should work without any other command sets. I went over my photoshop configuration with them and it was identical to theirs.
I'll be watching this one to see if there is anything here that helps me in the issues I seem to having.
jameslcross
Oct 02, 2006 08:46 |  #6
That's very weird!
Albert Einstein.
amccomis
Oct 02, 2006 13:37 |  #7
I convert to grayscale because it provides a neutral unbiased point to start from when doing sepia toning. Plus, changing modes guarantees me to be in the correct mode when I go to run the filters.
Also, as for "command not available" - remember, that some commands will apply to a selection or to everything depending on if you have a selection active or not. But, some things are not possible if you have a selection active. Also, some commands are not available in certain color modes.
jameslcross
Oct 05, 2006 17:46 |  #8
ssim wrote in post #2065526 (external link)
I may of found the solution :cool:
If you go into the action pallet menu,
go to Playback Options, you will see the following options
Accelerated
Step By Step
Pause For
Default is accelerated, I switched to step by step and my action now works!!
Let me know how you get on :D
Albert Einstein.
1,792 views & 0 likes for this thread, 4 members have posted to it.
Photoshop actions
1313 guests, 125 members online
