Thread started 03 Oct 2006 (Tuesday) 11:43
Monaco Optix XR; I quit...
rightaway
Joined Nov 2005
Oct 03, 2006 11:43 |  #1
I have tried to color balance my monitor with the Optix xr and always end up with a dull redish looking monitor.
I followed all the stps to the letter but failed everytime.
Anyone else that encountered that problem. My video card is a Matrox G550.
thanks
JMHPhotography
Oct 03, 2006 15:34 |  #2
rightaway wrote in post #2071428 (external link)
thanks
Sometimes when you've looked at your screen for so long and adjusting it using the eyeball method, when you finally do get it calibrated and profiled, it can look completely messed up when it is actually correct and your perception of correct is wrong. Try using it like this for a few days and see if your eyes don't adjust to it. I have the Optix XR and would say that it's accuracy is amazing when building monitor profiles. My prints have never looked better or more accurate. I'm talking about my profressional lab prints not my inkjet prints. And I use Mpix without the color correction. Also, this post is in the wrong section... it should be in the post production and printing section.
~John
(aka forkball)
Have a peek into my Gearbag. and My flickr (external link)
editing of my photos by permission only. Thanks
RobKirkwood
Oct 03, 2006 15:46 as a reply to  @ JMHPhotography's post |  #3
...and, just in case you think it's the display card causing problems, I've successfully calibrated TFT monitors connected to both Matrox G550 and P650 cards using a Spider 2 Pro system.
Rob
rightaway
Joined Nov 2005
Oct 03, 2006 15:57 as a reply to  @ RobKirkwood's post |  #4
Rob,
do you leave the matrox color management as default? and only use the monitor settings to calibrate it?
thanks
RobKirkwood
Oct 03, 2006 16:00 as a reply to  @ rightaway's post |  #5
I never touched the Matrox colour management for either the G550 or the P650, and have since replaced the Matrox display card with an Nvidia one anyway (had problems with the Matrox P650 seemingly unable to communicate properly with a Viewsonic widescreen DVI panel).
Rob
Tragerman
Oct 03, 2006 16:05 |  #6
I've had no problem with my Monaco rig. It's made a big difference in my color accuracy. When the color profile kicks in at each boot, it seems that the color shifts warm, but I get good consistent results. I've calibrated both my laptop brightview screen and desktop crt. Try it again and have another set of eyes looking over your shoulder as you perform the process. It sometimes helps.
http://tragerman.smugm​ug.com/ (external link)Canon 20D x2, Canon 10-22, Canon 70-200 2.8 L IS USM; Canon 17-55/2.8 IS USM, Tamron 28-75 2.8, Canon 28-135 IS, Canon 75-300 III USM (for sale), Canon D60 IR modified. 580EX, Sigma 500 DG Super. Save $5 on a Smug Mug membership - use this link: http://www.smugmug.com​/?referrer=TnVhKJgoJK8​gQ (external link)
tim
Light Bringer
Oct 03, 2006 16:18 |  #7
My Monaco thingy works fine, it's done quite a few machines now. I didn't even read the manual, I just plugged it in and went for it.
rightaway
Joined Nov 2005
Oct 03, 2006 17:33 |  #8
tim wrote in post #2072551 (external link)
Do you find the monitor reddish after?
tim
Light Bringer
Oct 03, 2006 21:07 |  #9
Nope, the monitor matches the prints. I'd call Monaco tech support if I were in your position.
lostdoggy
King Duffus
Joined Aug 2004
Oct 03, 2006 21:20 |  #10
I calibrate my monitor in the dark. Once it did with the TV on and the calibration was totally off. So now I shut off all the light and place a dark towel over it just to be sure and it has worked fine so far. Oh I use Spyder2 Suite, it doesn't adjust for ambient lighting like heuy and the Spyder 2 Pro.
rightaway
Joined Nov 2005
Oct 05, 2006 15:05 as a reply to  @ lostdoggy's post |  #11
Everything ends up being muddy brown...as in a wedding dress muddy brown... :confused:
I will try in the dark tonight. I already called the company. They said they would exchange the sensor. So good point for Monaco!
2,417 views & 0 likes for this thread, 6 members have posted to it.
1229 guests, 181 members online
