Trying to decide which to buy next-
100 2.0 or 100 2.8 macro
Someone please help me decide.
Thanks in advance
WildWolf Goldmember 1,022 posts Likes: 4 Joined Feb 2003 Location: NY More info | Oct 03, 2006 13:05 | #1 Trying to decide which to buy next- 5DMkIV
Pete-eos Goldmember 1,999 posts Likes: 2 Joined Jul 2006 Location: SW London UK More info | Oct 03, 2006 13:07 | #2 Shoot a lot of macro?
kidpower Senior Member 513 posts Likes: 1 Joined Apr 2005 More info | Oct 03, 2006 13:09 | #3 What type of pictures will you take (what will you use the lens for)?
I have never shot macro before but I like that style. I would also like speed to shoot sports in low light or indoors. Tough decision!!!! Why can't Canon or someone else make a really fast macro lens????? 5DMkIV
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Oct 03, 2006 14:20 | #5 I'd get the 85/1.8 first and see how it works on indoors/sports. No real reason to get the macro if you do not do a lot of that. 85 can do a fair job at macro (with an ext tube or two.) GEAR LIST
crn3371 Cream of the Crop 7,198 posts Likes: 2 Joined Mar 2005 Location: SoCal, USA More info | Oct 03, 2006 15:01 | #6 Really boils down to whether you want to start doing any serious macro work. Both are fast, sharp, lenses. Both are very good at portraits. One excells at macro, the other is one stop faster.
Oct 04, 2006 05:21 | #7 Get the 100 F2 and a set of Kenko extension tubes and you will have the best of both worlds and only spend about $40.00 more than if you bought the 100 Macro. Michael Springfield - Chattanooga, TN
LesterWareham Moderator More info | Oct 04, 2006 10:28 | #8 If you are really interested in macro then get the macro lens, it beats the pants off mucking about with tubes. A macro lens is a very handy walkabout lens also, allowing a wide range of magnification. Gear List
kidpower Senior Member 513 posts Likes: 1 Joined Apr 2005 More info | Both lenses are excellent. I have the 100 F2.0 and it's part of my indoor sports arsenal (I only have 3 lenses (they are all primes) and I shoot sports with each). It's a great indoor or outdoor sports lens depending on your style, where you sit, etc. Even if you don't shoot sports it's an outstanding portrait lens and great for all around use (again depending on how/what your needs are).
Dellboy Senior Member 343 posts Joined Aug 2006 Location: Ipswich Suffolk U.K. More info | Oct 04, 2006 11:51 | #10 WildWolf wrote in post #2071928 Why can't Canon or someone else make a really fast macro lens????? Macro lenses need to have a small front end because working at such close distances you don't want the lens itself blocking out alot of light. Hence macro lenses generally arn't faster than F2.8. Also for macro photography smaller appertures are the "order of the day" due to the very small DOF encountered at these magnifications, as such faster lenses are not normally required.
Oct 04, 2006 14:14 | #11 Dellboy wrote in post #2076002 Macro lenses need to have a small front end because working at such close distances you don't want the lens itself blocking out alot of light. Hence macro lenses generally arn't faster than F2.8. Also for macro photography smaller appertures are the "order of the day" due to the very small DOF encountered at these magnifications, as such faster lenses are not normally required. It may be worth pointing out that the 100mm macro's focus is v. slow ( deliberately so to insure acurate focus ) this would not be suitable for sports and action events. You really need to decide which is more important to you Sports or macro? Or buy both. The only compromise is the the normal 100/85mm and a set of tubes. Thank you!!!!! This is the answer I was looking for. I can not deal with slow focus. 100 2.0 (or 85 1.8 ) for me. 5DMkIV
JNunn Senior Member 538 posts Joined May 2006 More info | Oct 04, 2006 15:50 | #12 I bought the 100mm macro and I love it! I have used it more for telephot/portrait that I have for macro. It is extremely sharp.
JMW-Photo Member 242 posts Joined Jul 2006 Location: Southeastern Michigan More info | Oct 04, 2006 16:09 | #13 gasrocks wrote in post #2072016 I'd get the 85/1.8 first and see how it works on indoors/sports. No real reason to get the macro if you do not do a lot of that. 85 can do a fair job at macro (with an ext tube or two.) The 85 1.8 has a minimum focusing of 2.8 feet. Is that necessarily that great for macro?? span style="font-weight: bold;"JMW-Photo
LesterWareham Moderator More info | Oct 04, 2006 16:10 | #14 WildWolf wrote in post #2071928 Why can't Canon or someone else make a really fast macro lens????? Very fast lenses are often a compromise in optical performance. Macro lenses are designed to be well corrected for close distance work as well as normal working distances. Gear List
AeroSmith Goldmember More info | I'd also just say that the 100/2 is much more compact that the macro variant. Josh Smith
| Latest registered member was a spammer, and banned as such! 2934 guests, 168 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
