Thread started 03 Oct 2006 (Tuesday) 14:30
tripod for canon 500mm
seanm
Gallery: 25 photos
Oct 03, 2006 14:30 |  #1
Hi all,
I have never had a tripod before. Could you reccommend a the cheapest tripod which can support the canon 500mm f4l IS USM for me.
Thank you.
Sean
C&C welcome.
BradT0517
I almost caught fire
Oct 03, 2006 18:31 |  #2
Wow are you really thinking about getting a 500 that crazy
My Website (external link)
René ­ Damkot
Oct 04, 2006 04:33 |  #3
For 500mm I'ld get at least a Gitzo '3' series... Not exactely cheap.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
GilesGuthrie
Oct 04, 2006 05:07 |  #4
I think that to support a £4,400 lens, you need to consider which is the "best" tripod, not which is the "cheapest".
If the lens fell off the tripod, and I were your insurer, I would be taking a very close interest in what tripod you had, because if you support it on some £50 'pod, I might be looking for a denial of compensation on grounds of negligence on your part.
Seriously, think this through on a whole-system level.
Blipfoto (external link) - Flickr (external link) - Twitter (external link)
Canon EOS 1d X, 1d MkIII, 5d. Gear List
SkipD
Joined Dec 2002
Oct 04, 2006 06:07 |  #5
seanm wrote in post #2072057 (external link)
Hi all,
Merely "supporting" the lens can be done by a lot of cheap tripods. Now, though, you need to consider two things:
Will the tripod will keep the whole rig (tripod with camera/lens mounted) from falling over? This is a really critical factor which depends on the tripod's weight and how far apart the legs can go while still being sturdy.
Will the tripod will hold the camera/lens steady (say, in a breeze)? This is, of course, the primary reason for using a tripod.
You should be looking at something like the Bogen/Manfrotto 3021BPro and a decent head as an absolute minimum.
Skip Douglas
JonMoss
Oct 04, 2006 07:09 |  #6
Cod not agree more with Giles ..... you need a STRONG tripod for that lens! :)
Canon EOS 1D MkIII, Canon EOS 5D
300 F2.8
LIS, 200 F2.8LIS, 24-70 F2.8L, 17-40 F4L
100mm F2.8 Macro, Gitzo Carbon Monopod and Tripod + 4Macs
Blog (external link) and flickr (external link)
http://75.126.234.18/f​orum/Hi%20Steve, (external link)
DigitalWilderness
Oct 04, 2006 08:27 |  #7
For the 500mm, I would recommend you get a tripod and head that will hold a minimum of 16 pounds. You don't want to go smaller then that.
Dave
http://www.digitalwild​erness.ca (external link)
canuck88
Oct 04, 2006 15:02 |  #8
You don't need a $500 tripod to work this lens (it's 8.5lbs, not 20lbs)... so get something that holds about 16+ lbs. Check out my review on the Benro products in this forum - very solid. I've also owned a Velbon Carmagne (now sherpa pro I think) and it could hold around 25lbs. as well for about $240 USD.
Scott
5DII, 40D, + a bunch of lenses, studio strobes, & other stuff.
JNunn
Oct 04, 2006 16:04 |  #9
I wouldn't go "Cheap" and I wouldn't recommend "Light". That's a heavy and expensive lens that I wouldn't trust to any light tripod. My Bogen 3221W is fairly heavy and is up to the task, but I'd probably use a Wembley gimbal type head if I had that lens. That's not cheap either.
JBillings
Gallery: 68 photos
Oct 05, 2006 20:57 |  #10
I've got the 500 and am using a Gitzo 1325 with a RRS BH-55 ball head. And I use a SideKick too. Works great, but not cheap.
jb
Nature website (external link) -- Sports website (external link)
Mitcon
Joined Jun 2005
Oct 05, 2006 21:18 |  #11
I have to agree with the others that the last thing you want is a "cheap" tripod as they will give you nothing but frustration and/or broken gear. But that said you don't need to spend a billion dollars either. If you want something good but that doesn't break the bank have a look at the Amvona AT CF94 carbon fibre legs as they will handle upto almost 18lbs and then look at something like the Manfrotto 393 (Bogen 3421) gimbal type head.
I have both of these myself and someone I know loves this set-up now for his EF500 f4. He did use to have a Gitzo carbon fibre and a Wimberly but found he prefered my set-up to his and so got his own. The Amvona AT CF94 Dynatran carbon fibre tripod can be had for a good price Via Amvona's eBay outlet and the Manfrotto gimbal head from any good photography store and is a bargin at it's normal price IMO. Worth having a think about and a look at.
Cheers Wayne :D
EOS 30D+350Dx2+BG-E2+BG-E3+18-55MkII+EF 70-300IS/USM+EF 75-300IIusm+Sigma 50-500DG+Tamron SP90 f2.8Di+Sigma 17-70+Kenco MC7 2x+580EX+430EX
POTN Aussie club
seanm
Gallery: 25 photos
Oct 06, 2006 12:46 |  #12
Thanks all.
Sean
C&C welcome.
MarkoPolo
Joined Jul 2004
Oct 08, 2006 15:14 |  #13
Look at the Dynatran CF-94. (Amvona.com) Almost exactly the same specs as a Gitzo 1325. I have one coming soon and paid less than $100US on e-bay auction. I think you will be surprised (and impressed) with the quality.
Mark
Olympus OM-D E-M1 pro body, M.Zuiko 12-40mm f/2.8 Pro lens, M.Zuiko 50-200mm f/2.8-3.5 ED SWD lens, M. Zuiko EC-14 1.4 Teleconverter, M. Zuiko 60mm f/2.8 Macro lens, M.Zuiko 9-18mm f/4-5.6 lens, M. Zuiko 75-300mm f/4.8-6.7 II lens, Canon 400mm f/5.6 L lens with Canon to OLympus converter, Nissin Di-466 Flash
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 13, 2006 15:38 |  #14
One of the best "bargains" for handling a lens like this is the
Bogen/Manfrotto 3021Pro line of legs (approx $150.00)
with a Bogen 3421 head. (approx $160.00)
CDS' HOT LINKS
SolPics
Joined Jun 2005
Oct 13, 2006 17:48 |  #15
I use the 3021 Pro, and have a RRS BH-40 head with a sidekick, and it works great. The sidekick or the Bogen 3421 are essential for this lens if you want to take action shots.
SolPics
Cannon 5D 30D, 50 f/1.4, 85 f/1.8, 135 f/2.0 L, 200 f/2.8 L, 500 f/4.0 L IS
17-40 f/4.0 L, 24-70 f/2.8 L, 70-200 f/2.8 L IS, 100-400 f/4.5-5.6 L, 580 EX,
Gitzo Tripod, all sorts of bags.
2,726 views & 0 likes for this thread, 14 members have posted to it.
1047 guests, 103 members online
