I need your help to choose a right UV filter for my new 85mm F/1.2L.
It seems to me there's big difference in price 15-100$
Do you know if this one is good enough?
http://cgi.ebay.com …74906QQrdZ1QQcmdZViewItem![]()
Cheers
Evgueni
strok Senior Member 275 posts Joined May 2006 Location: Brampton ON, Canada More info | Oct 04, 2006 05:56 | #1 I need your help to choose a right UV filter for my new 85mm F/1.2L. Portfolio: http://strok.photosight.com
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Oct 04, 2006 06:00 | #2 It's not advertised as being multicoated - it's probably a low-end filter that you should avoid. If you intend to use a UV filter for "protection" (something I don't believe in), you should get the absolute best quality multicoated filter that is available. Skip Douglas
harrydog Member 146 posts Joined May 2003 More info | Oct 04, 2006 06:24 | #3 On an exellent lens like that, I would use only a high quality multi-coated filter. I don't think the one on ebay is multi-coated.
Oct 04, 2006 06:41 | #4 Thank you guys Portfolio: http://strok.photosight.com
LesterWareham Moderator More info | Oct 04, 2006 10:16 | #5 strok wrote in post #2074936 I need your help to choose a right UV filter for my new 85mm F/1.2L. It seems to me there's big difference in price 15-100$ Do you know if this one is good enough? http://cgi.ebay.com …74906QQrdZ1QQcmdZViewItem Cheers Evgueni You want the Hoya SHMC Pro1 filters Gear List
HrcRacing Goldmember 2,019 posts Joined Aug 2005 Location: NE Florida, USA More info | The SHMC or SHMC Pro1 are both fine filters. Each have 12 layers of coating and an effective light transfer of around 99.7%. Robert
koekeloer Member 184 posts Joined Oct 2005 Location: Netherlands More info | Oct 05, 2006 14:01 | #7 I bought a SKYlight filter for my 17-40, was that a bad move ? http://shutterstock.com/g/koekeloer
JNunn Senior Member 538 posts Joined May 2006 More info | Oct 05, 2006 15:49 | #8 koekeloer wrote in post #2080867 I bought a SKYlight filter for my 17-40, was that a bad move ? As long as you got a high quality skylight it should be fine.
koekeloer Member 184 posts Joined Oct 2005 Location: Netherlands More info | Oct 06, 2006 08:08 | #9 JNunn wrote in post #2081300 As long as you got a high quality skylight it should be fine. How do I know if it is high quality "multi coated, made in Japan" does not help I guess http://shutterstock.com/g/koekeloer
LesterWareham Moderator More info | Oct 06, 2006 09:57 | #10 koekeloer wrote in post #2084290 How do I know if it is high quality "multi coated, made in Japan" does not help I guess My filter is made by Tokina. At least it is multicoated, but it may only be multicoated on one side. Gear List
| Latest registered member was a spammer, and banned as such! 2666 guests, 160 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
