Thread started 01 Jan 2004 (Thursday) 10:58
EXIF data and SIGMA 70-200mm lens
WyzMan
Joined Oct 2003
Jan 01, 2004 10:58 |  #1
Hello,
I have a 10D and a new SIGMA EX f2.8 APO 70-200mm lens.
When I check out the EXIF data, after shooting at the full 200mm zoom, using either Photoshop or the CANON Fileviewer utility - I get a focal length of 456.0mm shown.
Is this common?
The lens data is reported correctly as 70.0 - 200.0mm, all other EXIF data looks OK as far as I can tell. (Aperture, speed, ISO ...)
When shooting at the shortest focal length, the EXIF data reads correctly - 70.0mm.
Can anyone confirm that their lens does the same or is it just me? (Or I am making some obvious mistakes here?).
Alan
WyzMan
Joined Oct 2003
Jan 01, 2004 11:04 |  #2
Sorry - one last point...
When I look at the EXIF data in the CANON utility, some pictures show the full story, a few miss out things like focal length and other stuff - this happens with lenses other than my SIGMA EX.
mattchase
Joined Apr 2003
Jan 01, 2004 11:33 |  #3
I also have this lens, and haven't noticed that it reports incorrect focal lengths in the EXIF info. I have noticed that it doesn't show all the values that some Canon lenses do, but that is normal. Different lenses send different specs to the camera, some sending more than others.
JABACo
Joined Sep 2003
Jan 01, 2004 11:51 |  #4
I haven't noticed anything of this sort with my Sigma. The only problem I have with the Sigma is when I use the 2x extender. At 200mm (400mm), it has problems with focusing correctly.
Happy New Year
Bradley
WyzMan
Joined Oct 2003
Jan 01, 2004 12:44 |  #5
Ha ha! I'm not the only one. Did some googling around and found that other folk are experiencing the same sort of problem.
http://www.photo.net …a-fetch-msg?msg_id=006uXJ (external link)
Thing is - can this be fixed or is there some firmware inside the lens which would need changing?
If have found that at around 140mm focal length, all reports as it should. Above 140mm or so, I get silly data, below 140mm, all is fine and dandy.
hickory
Joined Oct 2003
Jan 01, 2004 14:02 |  #6
I just checked some of my shots with my Sigma 70-200 and my exif is correct. I'll be interested to see what you learn about this anomaly.......
1Ds MK III, 5D MK II, 80D, EOS R, 50 f1.4, 24-105 IS L, 70-200 IS L,
tomdarby.org
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jan 01, 2004 14:14 |  #7
That is odd,. my exif all seems correct as well..
I run into exif problems with t-cons installed,. sometimes that will throw off the exif. (especially of you 'tape pins" )
CDS' HOT LINKS
4,261 views & 0 likes for this thread, 5 members have posted to it.
1240 guests, 137 members online
