Thread started 07 Oct 2006 (Saturday) 13:30
Monitor color calibration
fi20100
Slightly late
Oct 07, 2006 13:30 |  #1
As I’m doing both webdesign and photography, I’m in desperate need of color calibrating my monitors. At the moment I’m looking into a ColorVision Spyder2express. Does anyone have any experience of this product?
Can anyone suggest any great alternatives in the same price range... ~ 100 € / $. I would very much appreciate some advice :)
Stefan
5D3, 5Dc, 5Dc, 40D + 17-40L, 24-70L, 70-200L, 50/1.4, 85/1.8, 100L Macro and some other stuff.
flickr (external link), 5∞px (external link)
Bill ­ Roberts
revolting peasant
Oct 07, 2006 14:40 |  #2
Coincidentally I've just bought the Spyder 2 today and just finished calibrating my Eizo L768 display (I've just realised even that's an L)):o It's somewhat dependant on the monitor controls as some have more than others available for tweaking the settings.
It didn't make a huge difference but it was visible. So in one way it's comforting to think that I must have set it up reasonably close to optimum manually. I think the main thing is that it should give a known setting to be able to return to. By the looks of it, the major differences between the Spyder express, Spyder 2 and the Spyder Pro seems to be the software with the actual Spyder itself being the same unit. I don't suppose it compares to a true spectrophotometer (we use them at work for colour matching) but they cost a LOT more and it's hardly justifiable for my use.
So... possibly a litte early to comment more, but so far I'm pleased with it and certainly don't regret buying it.
Hope that helps a little anyway,
Cheers
Bill
BiLL
fi20100
Slightly late
Oct 07, 2006 15:38 |  #3
Thanks Bill :) It is great to hear from someone that has got the unit :)
Stefan
Miles
Joined Jul 2003
Oct 08, 2006 02:29 as a reply to  @ fi20100's post |  #4
I got one last week. Works brilliantly. Huge difference in images and now need to redevelop all my raws!!!
fi20100
Slightly late
Oct 08, 2006 04:55 |  #5
Miles wrote in post #2091381 (external link)
It was the ColorVision Spyder2express you got? :)
Stefan
fi20100
Slightly late
Oct 09, 2006 00:37 |  #6
Does anyone else have any experience with the ColorVision Spyder2express?
Stefan
tzalman
Fatal attraction.
Oct 09, 2006 03:53 |  #7
As an alternative you might consider the Pantone Huey. Its main advantage is that it has a roomlight sensor that automatically adjusts the display according to the ambient light, which is convenient especially in a home environment where you work both at night and during the day.
Elie
Elie / אלי
triumph
Joined Sep 2003
Oct 11, 2006 05:30 |  #8
Have Just purchased and used the spyder2express. Looking good.
Canon 5D + BG-E4 grip + POTN Strap
17-40L, 24-105LIS, 28-135IS, 100-400LIS, 50mm/f1.4 100mm macro, 1.4x converter, 2x550EX flash, Gitzo Tripod G1327 + 1376 Head.
Lowepro Dryzone + billingham 445 bags, flashtrax XT, TC-80N3
Selling;
Manfrotto 441 carbonfibre tripod + manfrotto 488 Head
50mm f1.8 mk1, sigma EX 2x convertor, remote switch RS-80N3
TeeJay
Joined Jun 2005
Oct 11, 2006 05:58 |  #9
Another vote for the "Pantone Huey" - couldn't be easier to set up, just hold the sensor to the (LCD) screen (rather than use the built-in suction cups) for a few seconds while it runs through its testing - and job done!
As TZalman said, the room sensor is quite good, adjusting the output based on ambient room light.
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
fi20100
Slightly late
Oct 11, 2006 06:05 |  #10
Ok thanks :) seems like I just might get to borrow a Spyder 2 from a friend in a week, so I might do that first, to get an idea how it is working :)
Stefan
SuzyView
Oct 11, 2006 06:11 |  #11
I just looked at the Spyder 2 and it costs around $70. I think I might go out and get one today. My Dell LCD does not match my prints at all so I better get that done soon. I've been compensating and it's driving me nuts!
fi20100
Slightly late
Oct 11, 2006 11:14 |  #12
Great! Tell me how you like it when you've got it :)
Stefan
Sladecj
Oct 11, 2006 11:14 as a reply to  @ SuzyView's post |  #13
I just bought the Spyder 2 express, and did my calibration. The change was obvious.
My only concern is that you are supposed to change your monitor back to factory defaults for all settings. I am pretty sure this is a bad idea. I did this and then got what is called "image persistance" or LCD screen burn. My factory default is brightness at %100 and the tool bar etc. started to burn in. This is fixable on and LCD and all is well. But as a result I toned down the brightness and re-calibrated and everything seems to be fine. Not every monitor is the same (has the same default settings) so I don't really se how this should be much of an issue. I suspect some people may just have their monitors so messed up they can be calibrated well.
rfreschner
ishka bibble
Joined Jan 2005
Location: Andover, CT...................... Go Red Sox!
Oct 11, 2006 16:45 |  #14
Sladecj wrote in post #2106469 (external link)
I don't understand how you would get burn in unless you waited a long time (like months) between changing back to default settings and calibrating. :confused: I just calibrated my monitor with the Spyder2PRO at the default settings and the calibration promptly knocked the brightness down below what I've been running it at for the 6 months I've had it.
Rick
"We both can't be wrong; I must be right"
Bob Welch
Sladecj
Oct 11, 2006 18:23 as a reply to  @ rfreschner's post |  #15
I don't understand. Are you saying the the software changed the brightness controls on your monitor on it's own? Doesn't the software just create a profile for color managed programs to use? The programs uses this profile to adjust things to display correctly on your monitor. I'm I wrong about this? Did you manually change your monitor settings during the calibration?
4,487 views & 0 likes for this thread, 9 members have posted to it.
1408 guests, 109 members online
