Thread started 09 Oct 2006 (Monday) 14:04
Circular polarizer - hmmmmmmmmmm
zzpethe
Joined Feb 2006
Oct 09, 2006 14:04 |  #1
Hello,
A few months back, I bought a no-brand CPF for both my 58mm and 70mm lenses. While I do see some real impact of using the filter overall, I do not see how turning the filter really makes a difference. I can see how the picture's quality/lights etc change as I turn it, but then the photo turns out the same no matter where the filter is turned. I tested several CPF positions on the same object and could not detect significant differences...
Am I doing somwthing wrong or do the filters not function well? DO I keep the filters or invest in brand-ones? It is strange since I can really see the overall impact of the CPF as compared to photos without....please help solve my dilemma!!!!!!!!
Thanks,
Zsolt
Heatseeker99
Oct 09, 2006 14:26 |  #2
I'm not sure what your problem is. What direction are you shooting in relation to the sun? You should be at a 90 degree angle to it for maximum effectiveness. When I rotate mine, I see a big difference in where the polarization goes, i.e. the skies or a body of water (lake).
A.J.
1D mkIII \ 24-105L \70-200 2.8IS II \ 35L \ 85 1.8 \ Kenko 1.4x \ 580EXII \ 430EX + every piece of Nikon/Photogenic equipment imaginable at the studio.
zzpethe
Joined Feb 2006
Oct 09, 2006 14:43 |  #3
Here is what I meant: I took several photos of the same object while turning the CPF. While I was able to see the difference with the turns in the viewfinder, the actuall photo did not show those differences; the photos all looked pretty much the same...
Olegis
Joined Apr 2004
Oct 09, 2006 15:02 as a reply to  @ zzpethe's post |  #4
As AJ noted - you have to shoot when the sun is at 90 degrres from the direction of your lens. See here (external link) for more details and example diagrams.
Best wishes,
Oleg.
www.Olegis.com (external link)
My equipment list
'I take orders from no one except the photographers' – Harry S Truman
Broncosaurus
Oct 09, 2006 20:50 |  #5
While the effects of a polarizer may be most notable when used 90° from the sun they can still be useful at just about any angle.
Chris from Whidbey Island
I've got a lovely bunch of coconuts:D
surfologist
Oct 09, 2006 21:03 |  #6
Very interesting site!
If i have a 70-200, and shooting outside, and sports, would you reccomend using a CPF?
My! Gear! Bag!
All of my money has gone to L!!
Broncosaurus
Oct 09, 2006 21:21 |  #7
surfologist wrote in post #2099165 (external link)
If you shoot around sun & water together you should have one.
With circular polorizer
IMAGE: http://static.flickr.com/103/265610582_66c90c6e3e.jpg?v=0
without CPL
IMAGE: http://static.flickr.com/116/265610580_304ef0359d.jpg?v=0
Rebel xt & EF28-135 @28mm
HighPlainsPhotographer
Oct 09, 2006 21:25 as a reply to  @ Broncosaurus's post |  #8
Maybe the no-brand CP is a POS? If you are anything but head on into the sun or have it behind your back, you should see an obvious difference in the view finder and in print.
Shaun
5D : 40D : 17-40 F/4L : 24-105 F/4L : 50 F/1.2L : 70-200 F/2.8L
A Window Into My World  (external link)
surfologist
Oct 09, 2006 22:50 |  #9
What about getting mulit coated one- Is it worth the upgrade? What will the coat do anyway?
My! Gear! Bag!
I ­ Simonius
Weather Sealed Photographer
Gallery: 19 photos
Location: On a Small Blue Planet with Small Blue People With Small Blue Eyes
Oct 10, 2006 03:43 |  #10
zzpethe wrote in post #2097343 (external link)
Hello,
Thanks,
Zsolt
you REALLY need to post some examples so we can SEE your problem
You WON"T see much difference with a CP filter if there is little or no sun and/or if you are not shooting 90% to the sun and if there are little or no reflective surfaces in your shot
You will notice a difference with multicoated filers as long as you know what it is you are looking for. At the moment you do not, so there is no point in shelling out for new filters until you have got the hang of the cheap version
Veni, Vidi, Snappi
Website  (external link) My Gear ---- (external link)
ruairidh
Oct 10, 2006 05:24 |  #11
It very much depends on what the subject matter of your shots is. CP cut down of the reflected light.
Suggest trying some test shots, for instance a landscape with blue sky. Position the sun at 90 deg. and take several short with the CPF at different degrees of rotation (e.g. 0, 20, 45, 70 and 9o etc). CPF also cut out the reflections from the surface of water or glass windows. Try taking a photo of a reflection on a loch/lake with the CPF in different positions.
The following image was taken on an over cast day, but without the CPF the rocks at the bottom of the river were not visible due to the reflections on the water's surface.
:mrgreen: Full Gear List :Canon 5D, EF 16-35 f/2.8, EF 24-105 f/4.0 IS, EF 70-200 f/2.8 IS
It's not how much kit you have, it's what you do with it that counts.......but at least L glass LOOKS good !!:D
View my Flikr Gallery (external link) - www.insiring-photography.com
curiousgeorge
Gallery: 13 photos
Joined Feb 2006
Oct 10, 2006 05:37 |  #12
If you can see a diffence through the viewfinder you should see the same difference in the final image. It doesn't make sense otherwise, unless you're using a compact camera.
Photos from my travels (external link)
Canon EOS R6 MkII | Canon EF 24-70mm f/4L | Canon RF 100-500mm f/4.5-7.1L | Samyang 14mm f/2.8
AdamJL
Oct 10, 2006 05:54 |  #13
surfologist wrote in post #2099584 (external link)
Stops glare.
Cheaper polarisers are known to give off glare in certain instances (though not always)... I've got a few multi-coated Hoya CPLs and I've never ever noticed glare in whatever my shooting conditions..
Takes off about 3 stops of light though, so be warned...
Gear
curiousgeorge
Gallery: 13 photos
Joined Feb 2006
Oct 10, 2006 05:59 |  #14
It's 2 stops. I've never found this to be a problem at 400ISO, shooting landscapes at f8 in bright conditions.
AdamJL
Oct 10, 2006 07:28 |  #15
curiousgeorge wrote in post #2100598 (external link)
It's 2 stops.
Not always. My CPLs sometimes drop 2 stops, mostly drop 3.
Gear
2,288 views & 0 likes for this thread, 10 members have posted to it.
2612 guests, 162 members online
