Thread started 11 Oct 2006 (Wednesday) 17:28
Autumn leaves
mlc
Oct 11, 2006 17:28 |  #1
I took this picture of leaves turning to autumn colours ( or fall colors for our friends the othe side of the pond!) Does the image work or is there too much going on - could it be cropped to give a more successful image? Any thoughts welcome.
Mike
5D Mk3; 7D; 24-105 F4; 70-200 F2.8 Mk2; 300 F2.8 Mk2; 500 F4 Mk2;1.4x and 2x Mk 3 Extenders; 055CXPRO3; Benro GH2
Hellashot
Joined Sep 2004
Oct 11, 2006 19:30 |  #2
Did you use a flash? Kind of looks like it.
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Oct 11, 2006 22:37 as a reply to  @ Hellashot's post |  #3
Kind of looks a little too bright to me. And this monitor always presents too dark, anyway. So if it looks too bright on THIS screen, then, yowza!
So I tried a couple of darker edits, one straightforward, another somewhat interpretive.
First edit is just with a multiplied layer.
Second edit is with the multiplied layer, flattened, then duplicated, Gaussian blurred and duplicated again. Top layer set to Soft Light, 90% opacity, middle layer set to Normal, 35% opacity.
Hope you like them.
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
Radtech1
Joined Jun 2003
Oct 13, 2006 07:50 |  #4
I hope you don't mind, but I find that your shot has a lot of potential, and I have been enjoying playing with it. Here are 2 more variations I like.
Rad
mlc
Oct 13, 2006 16:29 as a reply to  @ Radtech1's post |  #5
Thanks for the comments and ideas.
I didn't use flash for this shot although light was low so I did try a version using the on-camera flash (I am using a 350D) but the result was very flat - the flash took all the depth out of the picture - I didn't have my 580ex speedlite with me and no facility to move the flash off axis.
Rad - some really interesting variations - I like the last two you posted particularly - of those two the first is my favourite but the second is also really intriguing - how did you get that effect?
Mike
1,027 views & 0 likes for this thread, 3 members have posted to it.
Autumn leaves
926 guests, 117 members online
