Thread started 12 Oct 2006 (Thursday) 04:01
17-40L SCRATCH!
savone
Oct 12, 2006 04:01 |  #1
It seems I somehow got a small scratch on the front element of my 17-40L. I am not sure how this happened but if I had to guess I would say the time I pulled it out of the bag and noticed the front lens cap had fallen off. I was wondering, is this something I can send to canon to have fixed? Would it be worth it money wise?
grego
Oct 12, 2006 04:02 |  #2
You should first check if it even shows up in your photos. Shoot various things that provide rich colors. Shoot wide open and stopped down. See if anything even shows up.
Go UCLA (external link)!! |Gear|http://gregburmann.com (external link)SportsShooter (external link)|Flickr (external link)|
Livinthalife
Oct 12, 2006 04:50 |  #3
I doubt it will even show up. I wouldn't worry to much, but than again it really depends on how deep and long this scratch is. do what grego said, then make your decision.
-Andy-
muscleflex
Joined Jun 2005
Oct 12, 2006 06:17 |  #4
ouch - sorry to hear about this...but i sure would put a filter on a premium lens like this!!! i can't wait to get mine! lens that is...not the scratch! :)
:cool:Canon 1D MK III:cool: | Canon EOS 20D | Canon 16-35 II [COLOR=red]L [COLOR=black]| Canon 100-400 [COLOR=red]L IS | [COLOR=#000000]Canon 50mm II 1.8 | Canon 580 EX II
Master-9
Oct 12, 2006 06:24 |  #5
I bet ya this is one point against the no filter(only hood) campaign
From Decatur Georgia(USA)
Canon 40D+ BG-E2N, Canon 20D, Canon PowerShot G12, Canon PowerShot G7, Canon Rebel(Film)EF-S 18-55mm f4-5.6, EF 28mm f2.8, EF 50mm f1.8 Mk I, EF 85mm f1.8 USM, EF 24-70 f2.8L USM, EF 70-200mm f4L USM, Canon Speedlite 420 EX
SkipD
Joined Dec 2002
Oct 12, 2006 06:45 |  #6
The probability is high that is really is not a scratch, but a deposit left by something that got wiped across the lens.
Look at the "scratch" with a fairly high power magnifying glass or a loupe (10X or more)and see if it really has depth to it or whether it is something deposited on the lens.
Many folks have cleaned "scratches" off their lens with appropriate cleaning solutions. Sometimes they have needed to try a few different cleaning solutions, but cleaning was the answer.
If if is truly a small scratch, it probably will have no effect on your images. If you put a 1/4-inch diameter opaque sticker on the lens you will not be able to see it in an image.
Skip Douglas
Mike ­ V
Oct 12, 2006 07:19 |  #7
Except when you are shooting in backlit conditions it is possible to get a reflection off the scratch.
Canon can easily change the front element. Probably not cheap though.
It might be cheaper to E-Bay it and get a new one, rather than getting it fixed.
o o o o
steved110
Oct 12, 2006 07:32 as a reply to  @ Mike V's post |  #8
Sory to hear this - that's why I put a filter on all my lenses. Even a hood wouldn't have stopped that accident.
On the bright side, most likley the scratch won't affect the image. You can always have it repaired - they just replace the front glass.
Another option is if you have insurance, it might be worth claiming. check what a claim will do to your next premium though.
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Oct 12, 2006 08:41 |  #9
savone wrote in post #2109926 (external link)
It probably will not show up except perhaps under strong lighting conditions.
First check by shooting a plain even surface at minimum focal length and a small fstop, say f16 or f22 acuratly focus on the target surface as close to the minimum focus distance as you can.
I doubt anything will show but this should be worst case for the scratch showing in the image even faintly.
Secondly shoot with a bright light source in the frame and a dark background, you might want to try this in the street at night or by setting a lamp setup in a room at night. Expose so the general background is about a stop under exposed at various focal lengths and fstops.
This will check for flare and general loss of contrast which is the mostly likely symptom of damaged coatings. If you can, compare with a known good lens under the same conditions.
Macrophotography by LordV
jcw122
Oct 12, 2006 08:46 |  #10
The front element on L glass is not part of the optics, its a protective element IIRC.
"Ill show you."-John Hammond
:D "YES! I AM INVINSIBLE!"-Boris
ed ­ rader
"I am not the final word"
Oct 12, 2006 08:57 |  #11
jcw122 wrote in post #2110533 (external link)
you're talking about some of the long lenses, not the 17-40.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
savone
Oct 12, 2006 09:43 |  #12
Thanks for all the info guys, I will run some tests sat morning when I get a chance. As far as keeping filters on the lens, wouldnt that be counter-productive? I mean wouldnt a $60 filter degrade the optics at all? As far as keeping the hood on, that just isnt practical when carrying 4 lenses, body, and various other goods in the bag.
Thanks again!
Nick_C
Oct 12, 2006 09:47 |  #13
Sorry to hear that, I know if it was me that would drive me nuts, even if it didnt show in the shots things like that really annoy me.
Without sounding like "I told you so" this is the reason why we use UV/protection filters, some say a lens hood is good enough but I dont believe that for one second, the hood is only good for what its designed for, stopping light entering the lens & while the coatings on a lens front element are tough, it shows they are not that tough!
Nick :-)
Nick_C
Oct 12, 2006 09:50 |  #14
savone wrote in post #2110720 (external link)
Thanks again!
Buy a UV & try it, lots of us have run tests & find no image degradation at all, sharpness is identical with or without a UV, the ONLY time a UV can cause a problem is if your pointing almost up at the sun, lens flare can be quite bad then, but it would still be pretty bad without a UV in those situations.
I wouldnt get THE cheapest, but you dont need the most expensive either, I use a Hoya G Series which is the cheapest coated UV Hoya make & I leave it on all the time, ive never had any problems.
Nick :-)
ed ­ rader
Oct 12, 2006 10:15 |  #15
Nick_C wrote in post #2110740 (external link)
Nick :-)
and some say only use a protective filter when there is a high likelihood of accident, and we all know that accidents happen when we most expect them :D :D :D !
ed rader
12,492 views & 0 likes for this thread, 29 members have posted to it and it is followed by 3 members.
17-40L SCRATCH!
1314 guests, 135 members online
