Thread started 14 Oct 2006 (Saturday) 01:20
What lens?
Vini
Oct 14, 2006 01:20 |  #1
I have a budget of £350-£400 to spend on a lens, i wish to use for street photography.
Can anyone give me some idea which lens to look for?
Thanks.;)
MY PHOTOS
http://www.flickr.com/​photos/viniryan/ (external link)
MY GEAR LIST
[350D] [KIT LENS] [17-40L:D ] [SIG 105 MACRO] [SIG 70-300] [KENKO EX TUBES] [430EX] [FLASH BRACKET] [BG-E3 BAT GRIP] [MANFROTTO MONO+TRIPOD] [AND LOADS OF BITS]
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Oct 14, 2006 01:25 |  #2
tamron 17-50 is what I mainly use, I'm in the US, so I'm not sure about the price, but I think it'll fit in your budget.
Gallery: http://tomyi.smugmug.c​om/ (external link)
peterdoomen
Location: Lier, Flanders (northern, flemish speaking part of Belgium)
Oct 14, 2006 01:46 |  #3
Tamron 28-75 f/2.8 also fits the budget. It's my most used walk around lens. Will also go with a full frame camera in case you consider to ever buy one.
P.
Canon EOS 20D | Canon 70-200 f2.8L IS + Hoya UV Filter | Canon Extender 1.4x | Canon 50 f/1.8 | Canon 85 f/1.2L mk II | Tamron 17-35 f/2.8-f/4| Tamron 28-75 f/2.8 | Tokina 100 f/2.8 macro | Kenko extension tubes | Canon Speedlite 420 EX & Sto-fen Omnibounce| 80GB Flashtrax | Manfrotto Tripod 190 pro B & Joystick 322RC2 | Lowepro Micro Trekker 200
PDFs: Make money with ShutterStock (external link) - Make your own Tabletop Studio (external link)- Glass Buying Guide (external link)
My ShutterStock Gallery (external link)
kevin_c
Oct 14, 2006 04:17 |  #4
There may be some listed in this thread from our UK 'urban guru' Condyk
https://photography-on-the.net/forum/showthre​ad.php?t=155169
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
condyk
Africa's #1 Tour Guide
Oct 14, 2006 04:34 |  #5
Cheers Kev ... personally, I find a tad wider better than a tad longer, tho' it depends if your focus is mainly people or buildings type stuff. The 24-105mm IS L is great for people and the 17-40mm L is great for buildings/general. I had both and now use the widey. TW's suggestion is a good one as you get a bit more on the long end and speed is always good. Another 'radical' option is a 35mm prime. I have often used my Zeiss 35mm 2.4 just for a change and it really gives a different feel to the shots and helps you focus on your position re. subject and composition. Hard to beat a flexible, decent quality zoom tho. I'd probably go for the Tamron 17-50mm or a SH 17-40mm L with your budget.
https://photography-on-the.net …/showthread.php​?t=1203740
Alec ­ Trevelyan
Oct 14, 2006 12:30 |  #6
400 quid? That's about enough for a Cano ef 17-40 f/4 L. Can't do much better than that, and there's no way that Tamron stacks up :)
5D, 17-40mm f/4 L, 24-105 f/4 L IS
www.nhowephotography.c​om/Urban (external link)
condyk
Oct 14, 2006 13:04 |  #7
How do you know? You tried them both?
Vini
Oct 14, 2006 14:08 |  #8
Thanks guys. Ok, the price difference between the Canon 17-40mm f/4 L @ £503 and the Tamron 17-50mm f/2.8 @ £299 is alot. So is the L lens worth spending the £203.
The prices have come from Warehouse Express.
So if anyone can convince me to buy the canon, feel free to do so............ Up to now i'm going for Tamron.:D
MY PHOTOS
MY GEAR LIST
kevin_c
Oct 14, 2006 14:18 |  #9
"Look into my eyes. Look into my eyes. The eyes. The eyes. Not around the eyes. Don't look around my eyes. Look into my eyes... You're under. - You will buy a very expensive 'L' lens you don't really need.... " ;) ;)
-- K e v i n --
condyk
Oct 14, 2006 14:21 |  #10
I really enjoy my 17-40mm and the IQ and handling is excellent, but if I was spending £500+ I would go for the Tamron. It isn't going to be better and it doesn't have USM which is a pain, but to me it just seems to represent better value. BUT if you want an L well you have to pay the premium price.
Vini
Oct 14, 2006 14:39 |  #11
condyk, What is USM?:confused:
MY PHOTOS
MY GEAR LIST
condyk
Oct 14, 2006 15:04 |  #12
Vini wrote in post #2120006 (external link)
See near bottom of this page (external link)
peterdoomen
Oct 16, 2006 06:32 |  #13
Vini wrote in post #2119901 (external link)
:D
Also don't forget that:
- The Tamron 17-50 is not suited for full frame, in case you ever want that
- The Tamron is f/2.8 which is a stop faster. Even if IS can compensate for 2-3 stops, there is no alternative for a real fast lens.
P.
rickydiver
Oct 16, 2006 06:59 |  #14
I have both the Tamron and the Canon, they are both great lenses.
"400 quid? That's about enough for a Cano ef 17-40 f/4 L. Can't do much better than that, and there's no way that Tamron stacks up" Sorry Alec but unless you have both these lenses I think you are sadly mis-informed. My Tamron is sharper at F4 than the Canon and holds its own in all other areas. The lenses have different applications for me but both are tack sharp lenses and a joy to use, although the Tamron is not so great at low light focussing.
Ricky
Bodies: Canon EOS 1DS Mkii, Canon EOS 1Dmkiii, Canon EOS 30D, Canon G12.
Lenses: Sigma 120-300 f2.8,Canon 70-200L f2.8 IS, [COLOR=black]Canon 17-40L, Tamron 28-75mm f2.8 XR Di, Sigma 10-20mm, Canon 50mm F1.8 mkI, Canon 1.4TC.
Flash Guns: 580EX and 420EX
Alec ­ Trevelyan
Oct 17, 2006 15:59 |  #15
I started out in life with Tamrons. Had the 28-80 and the 70-300. At the time, when I would view images at 100%, without fail there was some blur. At some point I got it into my head to pick up the Canon ef 28-105. Wow. I was blown away--suddenly images taken with the same settings (the aperture range is the same on both lenses) were coming out sharper and with even better colors. Then 3 weeks ago I went out and bought the 17-40 L, and I was blown away again. So you can see, I've experienced some rather lackluster results from Tamron. Oddly though, my sharpest lens is the Canon 50mm f/1.8. It's not even a USM lens, and weighs in at a mere $75. But the quality is unmistakable. So sometimes you get what you pay for, sometimes you don't.
2,075 views & 0 likes for this thread, 11 members have posted to it.
What lens?
2809 guests, 134 members online
