Has anyone tried the SanDisk Extreme II on the S3 and does it work allright?
Oct 14, 2006 13:01 | #1 Has anyone tried the SanDisk Extreme II on the S3 and does it work allright? Canonman47
bandit1 Cream of the Crop 5,131 posts Joined May 2006 Location: sometimes Sunny South Devon UK :-) More info | Oct 14, 2006 13:23 | #2 Hiya Canonman47, Bandit 1
MaxZoom Senior Member 316 posts Joined Sep 2006 Location: Dublin, Ireland More info | 2GB should be fine. 1GB limit is a file size limitation on a video clip equivalent to about 8 minutes at top quality. Max
Bic_Mac Hatchling 6 posts Joined Oct 2006 More info | I use 2GB 133X billionton SD card, and I'm happy with it
kids_bus_driver Mostly Lurking 10 posts Joined Oct 2006 Location: Northern, IL More info | Before reading that article on 4GB size problems ("sticky"), I had bought an s3 and a 4GB 150x Ridata from meritline and have filled it several times. It formats at 3.8, and my s3 does stop at 1gb (if I press record again it will record another gigabyte, each time until I get to 3.8). I use it for video mostly. Is 1gb as far as the s3 goes as one video? S3IS, Lensmate 58mm, oly tcon 1.7x, The POD.
Thank you for all the answers. Seems it's riskfree to buy a 2GB card, so I'll buy a SanDisk Extreme II for the camera! Canonman47
dhbailey Senior Member 328 posts Joined Oct 2004 Location: New Hampshire, USA More info | Oct 15, 2006 08:02 | #7 Just to add my confirmation to the others: I have the 2GB Sandisk Extreme III cards and they work flawlessly, and I also have a couple Transcend 4GB 150x cards (currently $99 at www.pcconnection.com David
SaNdMaN82 Member 159 posts Joined May 2006 Location: Buenos Aires, Argentina More info | Oct 15, 2006 08:27 | #8 kids_bus_driver wrote in post #2121859 Before reading that article on 4GB size problems ("sticky"), I had bought an s3 and a 4GB 150x Ridata from meritline and have filled it several times. It formats at 3.8, and my s3 does stop at 1gb (if I press record again it will record another gigabyte, each time until I get to 3.8). I use it for video mostly. Is 1gb as far as the s3 goes as one video? Mmm... you should read more about the cam you have Greetings,
kids_bus_driver Mostly Lurking 10 posts Joined Oct 2006 Location: Northern, IL More info | Thanks sandman. I love this forum... have learned much already. S3IS, Lensmate 58mm, oly tcon 1.7x, The POD.
McRotterdam Member 31 posts Joined Apr 2006 More info | Oct 15, 2006 15:34 | #10 SaNdMaN82 wrote in post #2122538 And it's normal it formats at 3.8... I use a 150x 512 Mb, and i don't have all those 512 Mb... It's always less. Even the 16mb card that came with the camera, doesn't format 16 mb... It's perfectly normal. Makers of memory always do that, if you calculated 3.8 times 1024 kb you would get a number of 4.0000 etc, that makes 4 gb number. Canon S70, Canon Ixus 65 (named SD630 in the usa)
DanielS Hatchling 3 posts Joined Sep 2006 Location: St. Louis Park, MN More info | Oct 15, 2006 20:46 | #11 I thought I might point out that there is no such thing as SanDisk Extreme II. There is the standard line, Ultra II, and Extreme III. I'm currently using a 2GB Ultra II in my S3. So far with movie mode or continuous shooting I have had no problems. Canon A80 and Canon S3 IS
Oct 16, 2006 08:48 | #12 2GB cards are fine in the S2/S3. I have a 2GB 150X Transcend SD card in my S2 and it works flawlessly. Even better was the fact that it was only $32 or so at www.newegg.com Paul
logger Hatchling 8 posts Joined Apr 2003 More info | Oct 17, 2006 21:49 | #13 I have a scandisk ultra II 2gb and I was wondering why my video's have a glitch in them every 5 or six seconds... I wouldn't think this is normal. Canon new S3
DanielS Hatchling 3 posts Joined Sep 2006 Location: St. Louis Park, MN More info | Oct 17, 2006 23:09 | #14 One, it's SanDisk, not ScanDisk. Second, make sure to do a low level format of the memory card. Canon A80 and Canon S3 IS
cartvader1 Mostly Lurking 17 posts Joined Oct 2006 More info | Oct 18, 2006 14:09 | #15 Ultra II vs. Extreme III - is there anyone out there that has tried both of these types? Does the S3 take advantage of the faster read/write speed of the Extreme III vs the Ultra II?
| Latest registered member was a spammer, and banned as such! 2267 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
