I am not understanding the difference between a 100mm macro and a 100mm prime lens. Is it not the same thing?
Photolistic Goldmember 1,632 posts Joined Aug 2006 Location: Oregon City, Oregon More info | Oct 15, 2006 16:04 | #1 Permanent banI am not understanding the difference between a 100mm macro and a 100mm prime lens. Is it not the same thing? FOR SALE: Canon 30D, 10D, and D2000
braduardo Goldmember 2,630 posts Likes: 1 Joined Jun 2006 Location: Minneapolis, MN More info | Oct 15, 2006 16:10 | #2 The 100mm Macro has a signifigantly shorter minimum focusing distance, which allows you to get so close to your subject that the recorded size on your sensor is the actual size the subject is in real life. For example, you could make a dime fill the frame. With a normal 100mm lens, the dime would only fill a small portion of the frame.
Oct 15, 2006 16:20 | #3 Permanent banok tat makes complete sense!! Thanks FOR SALE: Canon 30D, 10D, and D2000
Choderboy I like a long knob More info | Gives you something else to look for when evaluating a lens: Maximum Magnification Dave
zacwolf Senior Member 416 posts Joined May 2006 Location: Boston More info | Oct 15, 2006 17:32 | #5 can someone explain why i was once told macro lenses are great for portraits?
sirsloop BigFoot 943 posts Likes: 2 Joined Oct 2006 Location: South River, NJ More info | Oct 15, 2006 17:42 | #6 they can still focus on things farter away than the minimum focus distance, so you could use a 60mm macro lens as a 60mm lens. no gear List
braduardo Goldmember 2,630 posts Likes: 1 Joined Jun 2006 Location: Minneapolis, MN More info | Oct 15, 2006 17:43 | #7 zacwolf wrote in post #2124299 can someone explain why i was once told macro lenses are great for portraits? Also, because they are EXTREMELY sharp lenses.
bolantej Goldmember 3,780 posts Likes: 7 Joined Mar 2005 Location: CAlifornia More info | Oct 15, 2006 17:45 | #8 zacwolf wrote in post #2124299 can someone explain why i was once told macro lenses are great for portraits? maybe because they have a larger max aperture, offering more control over DOF? Just a guess. A lot of the macro lenses out there are very very sharp, too. that could also be a reason.
braduardo Goldmember 2,630 posts Likes: 1 Joined Jun 2006 Location: Minneapolis, MN More info | Oct 15, 2006 17:56 | #9 Ok... Here we go... And one with a 180mm Macro lens. *Note, I think I had a set or two of extension tubes on*
braduardo Goldmember 2,630 posts Likes: 1 Joined Jun 2006 Location: Minneapolis, MN More info | Oct 15, 2006 17:58 | #10 bolantej wrote in post #2124335 maybe because they have a larger max aperture, offering more control over DOF? Just a guess. A lot of the macro lenses out there are very very sharp, too. that could also be a reason. Hey Jason! I'm still LOVING the 70-200...
PetKal Cream of the Crop 11,141 posts Likes: 5 Joined Sep 2005 Location: Nizza, Italia More info |
Mollym/CA Member 128 posts Joined Oct 2006 Location: Central Valley, CA More info | Wow. You must have a fast hand and eye. Is that the whole frame or a crop?
PetKal Cream of the Crop 11,141 posts Likes: 5 Joined Sep 2005 Location: Nizza, Italia More info | Oct 17, 2006 09:22 | #13 Mollym/CA wrote in post #2131252 Wow. You must have a fast hand and eye. Is that the whole frame or a crop? Pretty good demonstration of how fast the MkII is-- how many shots did you burn to get this one? Were you using the single-shot setting? Thankyou, that's an unprocessed JPG original.....if I was cropping it, the bird would not be flying out of the frame. With this lens I normally get a decent keeper ratio. But have not tried to shoot often anything smaller or faster than seagulls. Yes, I think single shot was used because they were not flying fast/erratic. Potenza-Walore-Prestigio
rdenney Rick "who is not suited for any one title" Denney 2,400 posts Likes: 3 Joined Jun 2003 More info | Oct 17, 2006 12:35 | #14 In addition to being able to magnify things to life size, macro lenses are also corrected for even performance into the corners, a completely flat focus plane, and zero distortion for copy work. I use my 50mm/2.5 macro as a copy lens, and it's sharp enough so that I can get results nearly as good as scanning on a flatbed scanner, and with much better color.
PetKal Cream of the Crop 11,141 posts Likes: 5 Joined Sep 2005 Location: Nizza, Italia More info | Oct 17, 2006 12:41 | #15 rdenney wrote in post #2132104 In addition to being able to magnify things to life size, macro lenses are also corrected for even performance into the corners, a completely flat focus plane, and zero distortion for copy work. I use my 50mm/2.5 macro as a copy lens, and it's sharp enough so that I can get results nearly as good as scanning on a flatbed scanner, and with much better color. The 50mm macro has 9 elements, compared to the 5-7 elements in most 50mm lenses. The extra glass is there to provide a finer level of correction and flatness of field. Rick "who needs a flat field and no distortion much more than 1:1" Denney An important feature indeed. Potenza-Walore-Prestigio
| Latest registered member was a spammer, and banned as such! 2832 guests, 161 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
