Thread started 16 Oct 2006 (Monday) 13:55
Any rules for shooting SUPER wide?
WildWolf
Joined Feb 2003
Oct 16, 2006 13:55 |  #1
What "rules" should I pay attention to when shooting super wide? Are there any tricks for shooting 10-20??? Thanks in advance
5DMkIV
Canon 24-105 L IS ; 70-200 L IS II; 100-400 L IS
430 EX; Feisol 3442 w/CB50D; Bogen 681B; POTN strap
PEACHMAN
Oct 16, 2006 13:58 |  #2
Ya. all the trees point to the center...all the legs look longer...light passing thru at the accute angles that it must create halos of darker colors at the outside...be ready to be happy!
The "eyes" have it !
sonnyc
Joined Jun 2005
Oct 16, 2006 13:59 |  #3
Watch out for your shoes...:D
The rule is... there's no rule.
Sonny
WildWolf
Joined Feb 2003
Oct 16, 2006 14:03 as a reply to  @ sonnyc's post |  #4
what about composition? How should u set up a composition for UWA? Rule of thirds still in effect?
5DMkIV
amarasme
Oct 16, 2006 14:06 |  #5
WildWolf wrote in post #2127844 (external link)
Level the camera, to avoid distortions. Unless you want distortion...
If shooting people, put them in the center of the image. Also to avoid distorted faces...
Rule of thirds still apply, unless you want to break it...
Canon EOS 5D, 20D
Canon 35 f1.4L, 50 f1.4, 85 f1.8, 135 f2L,
17-40 f4L, 24-70 f2.8L, 70-200 f2.8L IS
Rhinotherunt
Looking for a Rock
Oct 16, 2006 14:19 |  #6
I always challenge myself to try to shoot with the least amount of distortion with this lens. Unless, I want some distortion. :)
Ryan McGill
My Gearhttps://photography-on-the.net/forum/showthre​ad.php?t=592450
WildWolf
Joined Feb 2003
Oct 16, 2006 14:37 |  #7
Rhinotherunt wrote in post #2127925 (external link)
How do you that?
5DMkIV
ps2user
Oct 16, 2006 14:44 |  #8
do you still use the 1 over focal length rule of thumb for shooting between 10-22?
Canon 5D Body
Canon 16-35 L, 50 L, 85 L MK1, 24-105 L IS, Canon Speedlite 550EX
Sigma 70-200 Macro
cosworth
I'm comfortable with my masculinity
Oct 16, 2006 14:51 |  #9
I shoot one over focal length wide, I avoid my shadow and my feet. I also full the diffuser out on the flash.
Play with distortion and get creative. Photographers are afraid to paint outside the lines sometimes. Please do break the rules.
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
Rhinotherunt
Looking for a Rock
Oct 16, 2006 14:52 |  #10
If the camera is level you will get less distortions. Look at your vertical and horizontal lines, but if you want some distortion till the camera forward, back, or to a side...
Ryan McGill
Double ­ Negative
*sniffles*
Oct 16, 2006 15:52 |  #11
Depending on what you're shooting, you can really maximize your DoF by shooting at the hyperfocal distance... Basically everything will be sharp in the shot. Landscapes in particular are good subjects for using this technique.
With an UWA you can use the distortion to your advantage. Look for peculiar and not-so-typical angles to shoot from. Down low. Up high. From an edge...
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
sugarzebra
Oct 16, 2006 16:02 |  #12
For classic landscapes, keep the camera level, use the highest aperture possible (18-22 is good) and make sure the immediate foreground is in sharp focus (I often focus manually on something in the front third of the shot ensuring it will be in sharp focus and allow the great DOF to keep the back ground in focus as well). Have fun with the UWA ...its great.
Scott
Website & Blog (external link)
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Oct 16, 2006 16:02 |  #13
Shooting ultrawides require you to really try to force a sense of depth. A great rule to remember is to include something in the foreground, mid ground, and background to add a sense of depth.
Gallery: http://tomyi.smugmug.c​om/ (external link)
1,344 views & 0 likes for this thread, 10 members have posted to it.
2789 guests, 161 members online
