At new toy model technique. It was fun making these, but not sure if it looks right yet...
Post about the technique:
https://photography-on-the.net …php?p=2131644#post2131644
Rhinotherunt Looking for a Rock 7,129 posts Likes: 2 Joined Jun 2006 Location: Jasper, AL More info | Oct 17, 2006 10:47 | #1 At new toy model technique. It was fun making these, but not sure if it looks right yet... Ryan McGill
Rachellebee27 Goldmember 1,271 posts Joined Mar 2006 Location: Utah More info | Oct 17, 2006 11:16 | #2 Are you saying that you built these sceenes then shot them (I've seen some really cool real looking stuff in model train stores), or took pics of real things and then used PP to make them look little and fake? I don't understand. Kaylene
aacmckay Senior Member 534 posts Joined Aug 2006 Location: Winnipeg (Fondly known as Winterpeg) More info | Oct 17, 2006 11:22 | #3 Looks like a pretty good attempt. I'm not sure that this is exactly the way a tilt-shift would look. Then again I haven't studied tilt-shift shots all that much. Typically the shot that works best for this is one taken from a height looking down. Part of the problem with these is that the blur doesn't quite look distance related. It looks like it's just related to the position in the frame. Andrew
Rhinotherunt THREAD STARTER Looking for a Rock 7,129 posts Likes: 2 Joined Jun 2006 Location: Jasper, AL More info | Oct 17, 2006 11:27 | #4 Rachellebee27 wrote in post #2131776 Are you saying that you built these sceenes then shot them (I've seen some really cool real looking stuff in model train stores), or took pics of real things and then used PP to make them look little and fake? I don't understand. I'm not really big on the blurring, it almost seems that it was half on accident, like it was big chuncks. I'd like to see the roofs and the entire subject looking more sharp. I do like what you did with the coloring. Like you sucked out everything but the reds and oranges. It is a normal shot that is to look like a fake or a model. I am not 100% happy with the blurring yet either. Thanks on the color complement. aacmckay wrote in post #2131798 Looks like a pretty good attempt. I'm not sure that this is exactly the way a tilt-shift would look. Then again I haven't studied tilt-shift shots all that much. Typically the shot that works best for this is one taken from a height looking down. Part of the problem with these is that the blur doesn't quite look distance related. It looks like it's just related to the position in the frame. That is what I was afraid of. Back to the drawing board. Ryan McGill
Rachellebee27 Goldmember 1,271 posts Joined Mar 2006 Location: Utah More info | Oct 17, 2006 11:34 | #5 Try this, instead of a mask, select a rectangle, left edge to right edge, of your focus subject in the center, and feather a lot, I'd say 250 pixels, then hit delete, and click off your selection, and use the gaussian blur until you're happy. Go back to your main layer and select what you would like back in focus, using the magnetic lasso, then go back to your blurred layer and delete. Kaylene
Rhinotherunt THREAD STARTER Looking for a Rock 7,129 posts Likes: 2 Joined Jun 2006 Location: Jasper, AL More info | Oct 17, 2006 11:36 | #6 That would probably work much better... Ryan McGill
| Latest registered member was a spammer, and banned as such! 2673 guests, 161 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
