today i used a CP filter for the first time. the kenko CP was mounted on my 17-40.
the results were mixed but i certainly see potential for improving pictures.
one thing that i'm not too wild about is the partially dark sky which is most noticeable at the wide end of the lens.
do you use a certain length lens with your CP filter...or is there some other trick to getting a more even colored sky?
any insights to getting the best pictures with a CP or any non-technical links you can provide me with would be appreciated.
thanx!
ed rader
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FOTOTIME |
