It is often said when people are seeking advice of flash card purchases that they should opt for a greater number of smaller cards over fewer larger cards, the reason being cited that if you say get a corruption on a 8GBcard, you loose more than if you had a corruption on a 1GB card, i.e. all your egges in one basket.
Is this actually true? I have been thinking (uh oh) but I have no conclusions yet...
This is all theroetical I am attenping to get an interesting discussion going here
1. First lets say a card has the same chance of failure regardless of capcity for this excercise lets say 1 in 1000 hours of use. I cycle my cards so they all get used.
1. a: I own 8 1GB cards therefore there is a 8 in 1000 hour chance of a failure, however it will only affect 1/8th of my images. As statistics go after 10000 hours I would have had 80 failures and lost 80GB of images.
1. b: I own 2 4GB cards therefore there is a 2 in 1000 hour chance of failure, hoever it will affect half my photos. As statistics go after 10000 hours I would have had 20 failures and lost 80GB of images.
1.a and 1.b over time show no real difference.
2. Second lets say a cards chance of failure is based on capacity and will there is a 1 in 1000 hour chance per GB. Again I cycle my cards so they all get used.
2. a: I own 8 1GB cards therefore there is a 8 in 1000 hour chance of a failure, however it will only affect 1/8th of my images. As statistics go after 10000 hours I would have had 80 failures and lost 80GB of images.
2. b: I own 2 4GB cards therefore there is a 8 in 1000 hour chance of failure, hoever it will affect half my photos. As statistics go after 10000 hours I would have had 80 failures and lost 320GB of images.
2.a and 1.b over time show a greater risk in larger cards, i think this is possibly the more true scenario as the greater the capacity the more components the higher chance of failure.
What do you think? I know the failure rates are way too high for real life, these are just easy numbers, they also don't take into acocunt failures that don't cause the complete loss of a card
