TMR Design wrote in post #2144161
When you say flare do you mean flare from the sun or a bright sky? To avoid lens flare?
Stray light, whether artificial or natural, can adversely affect image quality, often producing flare and other unattractive specular artifacts. The sun is one major player in this. Using a lens hood, especially the one made by the lens maker for a specific/given lens, really helps in either blocking out or mitigating lens flare. You'll find that your images have better contrast, AF accuracy is better, and simply overall the images will be more pleasing. Lens hoods also serve as physical protection for your front element. Use your hood as much as you can.
