Thread started 20 Oct 2006 (Friday) 14:10
How do you test lens sharpness?
tange1
Oct 20, 2006 14:10 |  #1
I'm just curious but how do you test if a lens is decently sharp? I just got a 28-135mm IS USM from a friend and it seems great but I just wonder how sharp it is in comparison to my kit lens?
Canon Rebel Xti, EF-S 18-55mm kit lens
EF 28-135mm f.3.5-5.6 IS
50mm f/1.8
Battery Grip
430ex ii
Rhinotherunt
Looking for a Rock
Oct 20, 2006 14:32 |  #2
My guess is that the 28-135 is slightly sharper than the kit lens. The 28-135 is a great focal length and you will enjoy it.
Ryan McGill
My Gearhttps://photography-on-the.net/forum/showthre​ad.php?t=592450
TMR ­ Design
Joined Feb 2006
Oct 20, 2006 16:35 as a reply to  @ Rhinotherunt's post |  #3
Aren't there cards that have markings on them that are used to photograph and then look at sharpness and check DOF? I don't know what they are called but I have seen images in these forums with them.
Robert
Luckie8
Oct 20, 2006 17:37 |  #4
TMR Design wrote in post #2146960 (external link)
Yeah, where do you get those cards from?
I've seen them here before too.
Feedback
TMR ­ Design
Joined Feb 2006
Oct 20, 2006 17:56 as a reply to  @ Luckie8's post |  #5
I don't know. I was going to go hunting on the net to see what they are and if you can some initial testing by printing sometihng out, or a version of those cards.
Robert
PhotoScout
Oct 20, 2006 17:56 |  #6
I read in one of the major photography magazines that uses a specialized optical device along with specialized software that analyzes lenses, which the magazine uses for publishing the comparative results of two similar lenses. They claim to be the only ones who has this set up as it's very expensive. Maybe someone here also read the article last month (Sept or Oct) and can be more specific.
I did a Goggle search for self testing lenses and came up with lots of technical readings.
5D * 20D * XHA1S * HF11
EF 35mm f/1.4L USM * EF 50mm f/2.5 Compact Macro
EF 85mm f/1.8 USM * EF 16-35mm f/2.8L USM
EF-S 17-85MM f/4-5.6 IS USM * EF 24-70mm f/2.8L USM
EF 70-200mm f/2.8L IS USM * Ext EF 1.4x ll * Ext EF 2x ll * 580EX Flash
TMR ­ Design
Joined Feb 2006
Oct 20, 2006 17:57 as a reply to  @ PhotoScout's post |  #7
I just found this. I am not sure if it what we really want but it looks like it might be.
http://www.normankoren​.com/Tutorials/MTF5.ht​ml (external link)
Robert
steve_shelly
Joined Nov 2005
Oct 20, 2006 18:11 |  #8
I just take some pictures and if I'm just blown away then I know it's sharp...If I'm like um...maybe I made a mistake, then I get out the tripod and shoot a few dozen images in a controlled setting and realized I did make a mistake. I try to remember a monitor kind of skews the print perspective a bit.
Just Steve lately....:confused: .....
20D, 430EX, 16-35 I, Broken 50 1.4, 85 1.8 and other bits and pieces.
Pictures
http://michiganphotoda​d.blogspot.com (external link)
unix04
a title too
Oct 20, 2006 18:16 |  #9
wasnt there some sort of cheap battery test as well?
Currently:
Canon EOS 30D | 5D | EF 85mm f/1.8 USM | EF 24-105/4L IS USM | EF 70-200/2.8 IS USM | Speedlite 430EX
TMR ­ Design
Joined Feb 2006
Oct 20, 2006 18:25 as a reply to  @ unix04's post |  #10
I have been doing some testing on my Sigma 17-70mm f/2.8-4.5 lens just to get an idea of how fast and how sharp it is and so far it is performing very nicely, even in pretty low light. I did some DOF test too and I am pleased with those results.
Robert
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 20, 2006 19:07 |  #11
There's a nice little post (with pictures even) on this very subject in the EF Lens FAQ stickied at the top of this page.
CDS' HOT LINKS
fslshooter
Oct 20, 2006 19:17 as a reply to  @ CyberDyneSystems's post |  #12
Here's an easy way to test for sharpness. Mount a yardstick with easily readable numbers on it at a 45 degree angle either vertically or horizontally from where you shoot. Use center point focus, focus on the number 18, shoot then view the image on your computer monitor. If #18 is perfectly focused then the lens is sharp. If any other number is in better focus than #18 then the focus is off.
Jerry ~ Baseball is a game where only defensive players handle the ball and offensive players who hit successfully in only one third of their at bats are among the best in the sport.
Baseball Shooting Tips |++| www.jerryhalephotograp​hy.com (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 20, 2006 19:43 |  #13
Well, this is exactly how not to test for focus accuracy.
It may tell you about sharpness,. as sharpness does not necesarily require that you get the area in focus sharp, just something,. it's more about lens resolving power etc..
..but again I refer you to the article in the FAQ for the focus accuracy test.
Shooting an object at a 45* angle is a great way to get really nervous about AF accuracy.
Anyway,. my mistake re: the OP's original question. I jumped to the conclusion that you were talking about focus accuracy, and I think I was mistaken there.
Sharpness is a matter of resolving power, and we don't have a lot of easy ways to measure it. As Photocout mentions, this equipment whcih measure MTF etc. is a little out of reach.
Best thing to do is just to shoot and see what you think.
CDS' HOT LINKS
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Oct 20, 2006 23:12 |  #14
Since I will not be using a lens very often to shoot test patterns or lines of batteries, those tests seem rediculous to me. I prefer the shoot and appreciate method. If I use the lens and appreciate the shots I get then I like the lens and keep it.
Doc Klepper in the USA
I
fivegallon
Joined Sep 2004
Oct 20, 2006 23:28 |  #15
rklepper wrote in post #2148305 (external link)
Amen Doc ;)
Info
3,693 views & 0 likes for this thread, 15 members have posted to it.
2770 guests, 141 members online
