Thread started 21 Oct 2006 (Saturday) 21:25
Best UV Filter for 24-70?
cali
Oct 21, 2006 21:25 |  #1
My friend is buying the 24-70 Online tonight and asked me what was the best UV filter for the buck to get for the lens. A friend of hers told her that it didn't matter if she got a cheap one but is that true? Can you reccomend a good one that isn't too expensive or do you need to spend a lot on one?
20D, 17-85 kit lens, 70-200 F4, 50 1.4, Amvona AT CF 994 Tripod, Manrotto Monopod that I have never used and a 580EX Flash
ed ­ rader
"I am not the final word"
Oct 21, 2006 21:32 |  #2
cali wrote in post #2151606 (external link)
i buy multi-coated hoyas off of ebay for about $35 in the 77mm size.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
in ­ Japan
Joined Apr 2003
Oct 21, 2006 21:32 |  #3
If you're going to buy a UV filter for a pricey lens like the 24-70, you'll definitely want to get the best available. It would be foolish to put a $10 piece of glass in front of such a brilliant lens. Hoya or B+W are often the most recommended on this forum. I'm quite happy with my Hoyas.
Good luck making a decision.
Brandon
There's no day but today.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Oct 21, 2006 21:53 |  #4
One of these will do a good job:
http://www.bhphotovide​o.com …ghType=category​Navigation (external link)
Personally I don't use these much and rely on a hood instead. However, if you use a filter, B+W (MRC) are very good.
Bob
Col_M
Oct 21, 2006 22:26 |  #5
B+W or Heliopan would be my personal choice, multi coated of course :)
Col (short for Colin)
5D+Grip¦24-70L¦50 1.4¦100 2.8 Macro¦Sigma 70-200 EX DG¦430EX
garypasz
Oct 21, 2006 22:47 |  #6
I use Hoya 77mm UV Pro 1 Digital Multi-Coated Glass Filter, on all my lens and I've been very happy todate.
I would also recomend the Hoya 77mm Circular Polarizer (S-HMC) Super Multi-Coated Glass Filter - Thin
Also when looking for a filter glass for 24mm an wider get thinest glass filter possible.
Gary
5D mkII; D-Lux 5;
Lens: 24-105 f4 IS; 24-70 f/2.8; 70-200 f/2.8 IS; 85 f/1.2 II; Extender EF 1.4x II; EF 2x II; Flashs Metz 76 MZ-5; Canon 580EXII ; Leica CF-22
Double ­ Negative
*sniffles*
Oct 22, 2006 09:30 |  #7
Col_M wrote in post #2151767 (external link)
The only way to go.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Oct 22, 2006 12:22 |  #8
Don't buy third party off brand filters. Get a Canon UV filter for a Canon lens.
Gallery: http://tomyi.smugmug.c​om/ (external link)
inthedeck
Oct 22, 2006 12:33 |  #9
or, just skip it, and buy a circular polarizer instead. Money better spent. Just my opinion though...some may disagree.
MCSquared Photography (external link) on WWW
MCSquared Photography (external link) on Flickr
MCSquared Photography (external link) on IG
My name: Manish.
steved110
Oct 22, 2006 12:40 |  #10
Tee Why wrote in post #2153792 (external link)
I can't see why - apart from being hard to obtain, these are not advertised as being particularly suitable for digital cameras. Are they multi coated? why are they better than heliopan or hoya or B+W? Even Sigma produces an EX range of filters!
inthedeck wrote in post #2153820 (external link)
I'm one of those. A circular polariser should only be used for certain reasons - landscape photography mainly, when you need the effect. why would anyone leave it on the lens all the time, you just lose 1-2 stops of light. If you're suggesting to use no filters at all, leave the lens naked until and unless you want the CP - that's different.
But this is a pro thread , not asking should I use one, but which one should I use!
FWIW I use Hoya pro-1D multicoated UV filters on all my lenses, to keep the front elements clean and free of scratches. No hood will do that. You will not read a thread posted by a filter user moaning about a scratched lens.
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
ed ­ rader
Oct 22, 2006 14:24 |  #11
you've got to be kidding :D .
ed rader
Double ­ Negative
*sniffles*
Oct 22, 2006 16:35 |  #12
That's just about the last brand you want... Canon's are typically Tiffen... Which typically suck. ;)
jr_senator
Oct 22, 2006 17:48 |  #13
Off brand? Heliopan and B+W use glass from Zeiss, Schott and Schneider and their rings are brass, not aluminum. They are vastly superior to Canon's filters.
exerda
Oct 22, 2006 19:29 as a reply to  @ jr_senator's post |  #14
I switched from some off-brand to a B+W 77mm for my 300 f4L, and could see noticable improvements in some circumstances (the off-brand one had definitely introduced reproducable visible artifact, mainly in the background, in some combinations of aperture and background; the B+W does not). Spend the money on a good filter if you're going to use one.
Canon 6D; 7D mkII; EF 500mm f4L II; EF 24-105mm f4L; EF 300mm f4L IS; EF 16-35 f2.8L II; EF 24-70 f2.8L II; EF-S 10-22mm f3.5-4.5;1.4x TC III; 2x TC III Speedlite 580 EX II
85lesabre
Joined Feb 2006
Oct 22, 2006 21:15 |  #15
HAHAHAHAHAHAHAHAHAH...​...to avoid being banned for inappropriate language, I will simply say "NO COMMENT"
2,456 views & 0 likes for this thread, 18 members have posted to it.
2695 guests, 145 members online
