Thread started 21 Oct 2006 (Saturday) 22:40
Sigma 24-70 vs Tamron 28-75
JaGWiRE
Oct 21, 2006 22:40 |  #1
I'm curious, what the deal between the two is, and what you guys would recommend.
I want the sigma becasue it has the longer wide angle area, and because I have a 70-200 F4L on the way, I'de rather avoid the overlapping 5mm from the Tamron. I also plan to get a 12-24 sigma or tokina in the future and would love to have 12-200 covered without any gaps.
I am concerned about things like sharpness, focus noise, etc. My sigma 70-300 APO Macro focus really angers me, and it definitley is loud beyond belief.
I've heard the Sigma is more reliable though and that the Tamron has a little bit of quality control problems with soft copies.
I'm really not sure what to do.
Canon EOS 30D, Sigma 30 1.4, Sigma 10-20, Sigma 105 Macro, 135L, 430ex, Lowepro Mini Trekker AW, Manfrotto 3001pro w/486rc2 and 804rc2 head, Manfrotto 681 w/ 3232 head.
http://www.brianstar.s​mugmug.com (external link)
LightRules
Return of the Jedi
Joined Jun 2005
Oct 21, 2006 23:18 |  #2
The EX has a louder AF noise but the AF speed is a bit faster. It does weigh more than the Di, but OTOH, it weighs less than the Canon 24-70. Optically both can be very good and pleasing, but both have some QC issues (a minority report, I'm sure). If AF noise is a key consideration, the Tamron is quieter, though both lack any sort of ring USM/HSM and both lack FTM ability. Lots of people go back and forth between these 2 good 3rd party, FF-compatible standard zooms (and for good reason). I'm currently having a headache with my Tamron copy (currently at Tamron NY for the 3rd time -- blogged at my site), but when it's working, it's a good lens. The Sigma is the best bang for buck 24-xx out there and the Tamron the best bang for buck 28-xx out there.
JaGWiRE
Oct 21, 2006 23:23 |  #3
LightRules wrote in post #2151905 (external link)
I forgot to ask, they both are labelled macro, but are either of them decent, or just close focusing? Perhaps with extension tubes they are okay?
I have a couple friends who went through multiple Tamrons till getting a good copy, so I'm a little worried.
What is the weight diference? BH shows the Tamron at 1.5lb I believe and 500 or so grams, and the Sigma at 1.6lb and 700grams or so, so the numbers are definitley inaccurate as 200 grams definitley is more then .1lb. Is the lens really big cause of the 82mm filter size?
I think the weight is similiar to the 70-200 F4L on the way, so perhaps I should see if thats the type of weight I want for a standard walk around lens. More importantly though, what are the accurate weights on these lenses?
lkrms
"stupidly long verbal diarrhoea"
Oct 21, 2006 23:27 |  #4
You should be able to check the manufacturer's respective websites for specs on these lenses, which will include their weight.
Luke
Headshot photographer Sydney and Newcastle (external link) | Twitter (external link) | Facebook (external link) | Blog (external link)
JaGWiRE
Oct 21, 2006 23:31 |  #5
linarms wrote in post #2151940 (external link)
Your right.
The sigma is 700 grams and the Tamron is 510grams.
Just trying to think how much 190 grams will feel like. It's 1.12lb vs 1.54lb. I don't think it'll feel all that different, although the lens may be larger in diameter cause of the huge filter size.
I'm wondering as well though now, which is considered better in build quality, regardless of weight?
jr_senator
Oct 21, 2006 23:33 |  #6
JaGWiRE wrote in post #2151811 (external link)
I'm curious...what you guys would recommend.
Canon's 24-70L
ed ­ rader
"I am not the final word"
Oct 21, 2006 23:34 as a reply to  @ JaGWiRE's post |  #7
the tamron 28-75 is probably regarded as the best third party mid-range zoom.
if it had a ring USM and a 24mm wide end i probably would still own it :D .
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
JaGWiRE
Oct 21, 2006 23:36 |  #8
jr_senator wrote in post #2151959 (external link)
Canon's 24-70L
Yeah, perhaps the idea that I'm looking at third party lenses didn't convey the idea that I am not looking to spend that $.
Ed Radar, has anybody on here done comparisons with two good copies? I really would like the 24-70 focal length more then the Tamron. And then if I upgrade later to the Canon 24-70L I'll have gotten used to the focal length.
ed ­ rader
Oct 21, 2006 23:39 |  #9
JaGWiRE wrote in post #2151969 (external link)
there have been many comparisons and i think the tamron has the edge but the sigma is close.
28mm is a deal killer for me too on my walkaround.
if you gotta have 24mm it's the sigma or the brick, and i have the brick (24-70L) :D .
ed rader
JaGWiRE
Oct 21, 2006 23:42 |  #10
ed rader wrote in post #2151980 (external link)
ed rader
Do you find yourself needing the extra 4mm wide? I feel that the 5mm on the zoom won't do much, and I have that FL covered with the Canon 70-200. Like I said before, I think I'll end up with a cheaper ultra wide angle like the Tokina or Sigma 12-24, and I want no gaps in my focal lengths if possible.
ed ­ rader
Oct 21, 2006 23:48 |  #11
JaGWiRE wrote in post #2151987 (external link)
i absolutely need 24mm. 28mm is like no wide angle. 24mm is like P&S WA. with a walkaround that begins at 28mm i am switching lenses far too often.
i know this from trial and error because i have tried several of each.
when i had the tamron 28-75 i also owned the 17-35. i was a lens swapping fool in lens-change hell.
what i did was get a 24mm walkaround and increased the long end on my short zoon -- 17-40L -- and i am muuuch happier :D !
YMMV but i gotta have 24mm.
edit: for sure the 4mm on the wide end is far more important than 5mm on the long end, which you probably wouldn't even notice. also, don't be scared of a little overlap -- it's a good thing imo.
ed rader
JaGWiRE
Oct 21, 2006 23:50 |  #12
ed rader wrote in post #2152006 (external link)
what i did was get a 24mm walkaround and increased the long end on my short zoon -- 17-40L and i am muuuch happier :D !
ed rader
I have a feeling it's going to be the same for me. Guess the sigma is my only choice :).
ed ­ rader
Oct 21, 2006 23:59 |  #13
JaGWiRE wrote in post #2152014 (external link)
if you have doubts you probably are right. the tamron is a great lens but it just wasn't wide enough for me.
plenty of guys swear by the sigma so it'll probably work fine for you but make sure to factor in the cost of filters if you use them.
good luck!
ed rader
JaGWiRE
Oct 22, 2006 00:20 |  #14
ed rader wrote in post #2152047 (external link)
good luck!
ed rader
Well, UV filters for all my lenses seem to be topping out at high prices, especially when you think about how much it costs to get good enough glass to protect an L without affecting the quality, so at this point I'm going just with hoods. I'de love all those crazy filters, but they are #1 pricey, and #2, the lenses I want to buy all have varied filter sizes.
Juan ­ Zas
Oct 22, 2006 05:47 |  #15
I think you can not go wrong with both.
Someones we have the Siggy and it is an excellent piece of glass. I did bought it following the reports/advice of LightRules in that time (I think the Tammy was not in the market yet) and I am very happy. I have a good copy and it´s a wonderful lens: sharp even wide open, nice contrast, 24 mm, etc. Cons: Heavy when you are the whole day hanging up with it from your neck and not USM; but I can live with it. The results are worth. I did pay $350 for it !!
In the other way, the Tammy it´s also a good lens. You can see many reports/reviews over it.
Canon EF 24-70 L: Sure it´s very good (also there are some copies with issues) but I can not afford it, I am not a pro, and I did choose to save my money to invest in other lenses.
It´s your choice !!
Cheers
Juan
My Photo Gallery (external link)
3,327 views & 0 likes for this thread, 10 members have posted to it.
2695 guests, 145 members online
