Thread started 22 Oct 2006 (Sunday) 02:19
Which filters to get?
aLFaDaRK
Oct 22, 2006 02:19 |  #1
Well I've pretty much settled on getting the Canon EOS 400D sometime in the near future, and I've seen the usefulness of circular polarizers, neutral density filters, and I love the effect from gradual tobacco filters.
The question I have is - what brand should I buy from?
I know Cokin filters are well known, and they have all the types I need, but I've also heard from some people that they aren't very good - despite others saying they are.
So what would your recommend?
This is for a 17-40mm f/4L lens btw, and I don't know what the deal is with rear gel filters? If someone could explain that too, that would be great. :)
Canon EOS 5D Mark III, Canon Speedlite 580EX II
Canon EF 16-35mm f/2.8L USM, Canon EF 35mm f/1.4L USM, Canon EF 50mm f/1.4 USM, Canon EF 85mm f/1.2L USM, Canon EF 135mm f/2L USM
Apple 15" Retina Macbook Pro
Juan ­ Zas
Oct 22, 2006 05:19 |  #2
I normally use B&W, good quality at a good price. Many professionals use them here in Europe.
Cheers
Juan
My Photo Gallery (external link)
steved110
Oct 22, 2006 06:09 as a reply to  @ Juan Zas's post |  #3
Cokin filters are square and fit into a holder that is attached to the front of the lens. this sort of set up is essential for using graduated filters. Lee filters are very similar in set up, but are higher quality and cost a lot more than Cokin.
The other kind of filters you can get screw onto the front of the lens. they are not really suitable for graduated filters, and come in varying sizes depending on the filter thread of your lenses.
For landscape photography 0.3, 0.6 and 0.9 graduated neutral density filters ( or grey grads with cokin) are ideal. tobacco grads are a bit 80's, they have kind of gone out of fashion. But if you like it, that's what matters.
Straight neutral density filters are useful for slowing the shutter speed to increase motion blur eg waves and waterfalls - but IMO this effect has also been overdone of late. also, a circular polariser will give a similar effect as they reduce light by 1-2 stops anyway.
For setting up, I'd suggest getting the Cokin P series, with the relevant adapters so the mounting bracket will fit all the lenses you want to use for landscape stuff, some grey grads ( Cokin don't make true neutral density) and a tocacco grad if you have to, and then get a good multicoated circular polariser that fits the lens or lenses you wish to use - Hoya and B+W are names that are recommended regularly.
I'd also advise getting multicoated UV filters to keep the front elements of your lenses clean - hoods can provide physical protection, but they don't keep lenses clean like a good filter. there are a lot of arguments about this, about half of us use them and half don't. Those of us who do, don't post threads like ' I scratched my lens - what can I do now?' ;)
Final bit of advice, always keep filters scrupulously clean. any dirt increases the risk of flare. And buy the best quality you can afford.
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
jr_senator
Oct 22, 2006 08:44 |  #4
If one needs to use a filter then B+W or Heliopan are the ways to go.
Double ­ Negative
*sniffles*
Oct 22, 2006 08:51 |  #5
jr_senator wrote in post #2153116 (external link)
Yep!
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
aLFaDaRK
Oct 22, 2006 11:08 |  #6
I can't use gradient filters with B+W though correct?
Because that would be one of the largest benefits to me.
Anyone know anything about the gel filters? I don't know what they are but I'm curious to know
samsen
Oct 22, 2006 11:19 |  #7
Filter Brand:
If your budget allow spending: B&W
If not : Hoya (Green series for more budget oriented ones, Ultra if you can have it)
Avoid cheap ones, you end up spending more at the end.
Filter type:
1- UV (Must form minute one) as protector of your precious glass
2- CPL the only one that can make a lot of difference on most situations.
3- Others as especial need may be.
Weak retaliates,
Strong Forgives,
Intelligent Ignores!
Samsen
Picture editing OK
Jon
Joined Jun 2004
Oct 23, 2006 14:51 |  #8
Hoya HMC (or better), B+W MRC or Heliopan for circular filters. I use Singh Ray grads (external link) in 2 and 3 stops, soft and hard grad, in a Cokin P WA holder.
I use UV filters on any lens I can, as I'm frequently out in strong winds, prop/jet wash, or doggy nose areas. I want to keep blowing debris and/or noseprints off the lens proper. Then good quality circular polarizers. I actually have 3x77 mm CP(slim for the 24-70 - the 5D demands this - and I'm likely to be using both the 70-200 and 100-400 at the same time outdoors) as well as one each of the other filter sizes my lenses need. The 15-30 Sigma takes a rear gel filter - there's a snap-in frame to hold the gelatin filter flat (and don't try to cut corners by using a plastic filter here - they're thicker so imperfections will cause more problems), accessable only with the lens off the camera. Some longer lenses have drop-in filter holders fo either gel or glass filters. The rear gel filters are much thinner than the Cokin/Lee/Singh Ray front-mounted plastic filters, so more fragile and more susceptible to manufacturing or post-manufacturing abuses. Gels, by the way,are very vulnerable to moisture, so keep 'em dry.
Jon
Cocker Spaniels
TMR ­ Design
Joined Feb 2006
Oct 23, 2006 15:12 as a reply to  @ Jon's post |  #9
I just got a Hoya UV and CP. I saw the heliopan and I am sure they are excellent but kind of expensive. If I had L lenses I would not try to skimp at all in any area but I have been told by many that the Hoya's are good filters with good coatings and should serve me well for lenses like the Sigmas.
Robert
Double ­ Negative
*sniffles*
Oct 23, 2006 15:31 |  #10
TMR Design wrote in post #2158779 (external link)
Definitely... The Hoya Pro1 line is decent and much cheaper. It's not a Heliopan/B+W but should be just fine.
jr_senator
Oct 23, 2006 15:36 |  #11
Double Negative wrote in post #2158869 (external link)
Just be sure to buy a filter wrench when you order the filter.
1,209 views & 0 likes for this thread, 8 members have posted to it.
2694 guests, 145 members online
