Thread started 22 Oct 2006 (Sunday) 08:32
30D low light -HELP!
totalbeginner
Oct 22, 2006 08:32 |  #1
Last night I decided to try and capture some star trails, so I set up at the bottom of the garden in pitch darkness and tried some test exposures. I made 2 captures, both at 4minutes with different apertures to get a feel for the light. Both looked pretty good, but I decided to go with f/8.
I released the shutter and set my stopwatch for 30minutes. After waiting patiently I let the latch go on my remote release and waited to see the results... The red CF access light came on and "Busy" flashed on the LCD, but no image. After waiting 5 minutes, I gave up. The only way I could unlock my camera was to open the BATT compartment. What did I do wrong?
The 4minute exposures came up straight away, so why did my 30min exposure lock up the camera?
Any advice would be greatfully recieved! Many thanks!!
View my gear list HERE
Don't submit to stupid rules, be yourself and not a fool. Don't accept average habits, open your heart and PUSH THE LIMITS!
PAFC2004
Oct 22, 2006 08:37 |  #2
Do you have long exposure noise reduction on? If you do, it will take the same amount of time as the exposure to reduce noise. So your 30 minute exposure will take an additional 30 minutes following the actual exposure.
Canon 5D MKii |Canon 350D | EF 17-40L | EF 70-200 2.8L | 580EX II | 430EX | EF 1.4x T/C II | EF 50 1.8II | Q6600 + 8800 Ultra
markyb
Oct 22, 2006 08:37 |  #3
the longer the exposure the longer the write to the card.
not 100% sure but i think a 30 min exp will take almost as long to write to card
Canon EOS 30 D EOS 350 D canon eos 5d mk1, 100-400 L / 24-70 L / 70-200 ,canon eos 17-40 LL F4 / 10-22 /50 1.8, Sigma 105mm 2.8
http://markbarnes.foto​pic.net/list_collectio​ns.php (external link)
totalbeginner
Oct 22, 2006 08:51 as a reply to  @ markyb's post |  #4
Ah, ok... just reading about that now in the manual. It says that the long exposure NR is activated after 1sec, so why didn't my 4minute exposure take another 4 minutes to write??
PAFC2004
Oct 22, 2006 08:53 as a reply to  @ totalbeginner's post |  #5
Are you sure NR was on for that exposure?
totalbeginner
Oct 22, 2006 09:04 as a reply to  @ PAFC2004's post |  #6
I've always left it in AUTO. Is it best to switch it off for very long exposures? Will I be able to correct the noise in PP???
markyb
Oct 22, 2006 09:17 as a reply to  @ totalbeginner's post |  #7
on my 350d its either on or off no auto
Tareq
"I am very lazy, a normal consumer"
Oct 22, 2006 10:17 as a reply to  @ markyb's post |  #8
i left that option always on, should i turn it off if i shoot in daylight or high speed short exposure? and what if i don't use it even with long exposure can that be bad for shots to be so noisy and can't fix even with Noise reduction softwares?
Galleries:
http://hamrani.deviant​art.com/gallery/ (external link)
Facebook (external link)
weemannie
Oct 22, 2006 12:20 |  #9
Tareq wrote in post #2153405 (external link)
It won't kick in for normal daylight exposures, so you can leave it on. I turn NR off for test shots when doing long exposures, but always turn it back on before taking the shot I hope will be a winner :lol: Try some test shots with NR off at higher ISO's and see what you think.
Regards, Trevor
5D MkIII, 60D, Zuiko 24mm, Zeiss ZE 21mm and 50mm 1.4, 70-300L, 10-22
http://www.scotlandima​gery.com (external link)
nburwell
Oct 22, 2006 14:35 |  #10
totalbeginner wrote in post #2153194 (external link)
Long exposure NR is either on or off. There is no 'auto' setting for it. If you choose to leave NR off, you can use a program like Noise Ninja to correct the nose in the PP phase.
totalbeginner
Oct 23, 2006 09:17 as a reply to  @ nburwell's post |  #11
C.FN-02 Long exp. noise reduction
0: Off
1: Auto
For 1 sec. or longer exposures, noise reduction is performed automatically
if long exposure noise is detected. Setting this to [Auto] is effective in
most cases
2: On
Noise reduction is performed for all exposures 1 sec. or longer. Setting this
may reduce the noise even for exposures which would not have been
noise detected/reduced at the [Auto] setting.
totalbeginner
Oct 23, 2006 09:20 as a reply to  @ totalbeginner's post |  #12
I think the above probably answers my question. I guess it's possible that the AUTO setting didn't detect any noise during the 4minute exposure and so the image was "written" fairly quickly. However the 30min exposure probably produced detectable noise and so the write time would have been 30min also.
Many thanks for all your help!
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Oct 23, 2006 09:21 |  #13
http://www.digitaljour​nalist.org/issue0608/t​ech-tips.html (external link)
Tech Tips by Chuck Westfall August 2006
Got the 5D and love it. Question: Long exposure noise reduction. Is there any reason to ever turn this off? It's an option so there's got to be a reason but you got me! Also, I assume this does not affect RAW files?
For most EOS 5D users, it makes sense to leave the camera's long exposure noise reduction function turned on all the time. The main reason why we offer the ability to turn this feature off has to do with the amount of time it can take for the camera to process the noise reduction algorithm between frames. Fortunately, this only becomes a factor at ISO 1600 and 3200, which are sensitivity settings that many users would never select for time exposures. However, when the 5D is set for these ISO speeds and the long exposure noise reduction function is on, the camera requires an interval equal in length to the original exposure in order to process the noise reduction data for exposures lasting 1 second or longer. Turning off long exposure noise reduction under these conditions allows the photographer to eliminate the delay between frames that would ordinarily occur.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
1,441 views & 0 likes for this thread, 7 members have posted to it.
2760 guests, 155 members online
