If I have the 10 second delay on, I can focus, press the shutter button all the way down and move the cam while the time ticks down, and have that thing still in focus ?
90blackcrx Senior Member 985 posts Joined Sep 2006 More info | Oct 22, 2006 13:19 | #1 If I have the 10 second delay on, I can focus, press the shutter button all the way down and move the cam while the time ticks down, and have that thing still in focus ? Canon 40d
cdifoto Don't get pissy with me 34,092 posts Likes: 48 Joined Dec 2005 More info | Oct 22, 2006 13:22 | #2 90blackcrx wrote in post #2153949 If I have the 10 second delay on, I can focus, press the shutter button all the way down and move the cam while the time ticks down, and have that thing still in focus ? No. You can't move the camera once you've locked focus and started the countdown. It's the same as shooting normally. Move the camera enough and you move out of the focal plane. Did you lose Digital Photo Professional (DPP)? Get it here
I'm not talking about moving it a few yards or anything, just millimeters. Canon 40d
cdifoto Don't get pissy with me 34,092 posts Likes: 48 Joined Dec 2005 More info | Oct 22, 2006 13:37 | #4 Depends on your depth of field. Did you lose Digital Photo Professional (DPP)? Get it here
Oct 22, 2006 13:38 | #5 cdi-ink.com wrote in post #2153977 Depends on your depth of field. Why would that matter, say I focus on a candle ( direct center ) , then press the shutter all the way down. While the camera is counting down, move so the camera is to the right. Your telling me the candle won't still be in focus ? Canon 40d
cdifoto Don't get pissy with me 34,092 posts Likes: 48 Joined Dec 2005 More info | Oct 22, 2006 13:40 | #6 90blackcrx wrote in post #2153980 Why would that matter, say I focus on a candle ( direct center ) , then press the shutter all the way down. While the camera is counting down, move so the camera is to the right. Your telling me the candle won't still be in focus ? Like I said, it depends how much depth of field you have. The more depth of field you have, the more you can get away with moving before the subject falls out of the plane of focus. Did you lose Digital Photo Professional (DPP)? Get it here
deadpass Goldmember 3,353 posts Joined Jun 2006 Location: phoenix, az More info | Oct 22, 2006 13:50 | #7 if the front of the lens and the plane of the candle are both parallel, then moving the camera to the side would not pose a problem, but you'd have to make sure your focal length was exactly the same a camera
Oct 22, 2006 13:54 | #8 deadpass wrote in post #2154016 if the front of the lens and the plane of the candle are both parallel, then moving the camera to the side would not pose a problem, but you'd have to make sure your focal length was exactly the same Well I would be on a tripod Canon 40d
Dorman Goldmember 4,661 posts Joined Feb 2006 Location: Halifax, NS More info | Oct 22, 2006 17:24 | #9 I can't figure out why you would want to move the camera/tripod during the countdown?
Oct 22, 2006 18:17 | #10 Dorman wrote in post #2154732 I can't figure out why you would want to move the camera/tripod during the countdown? Easier to do this, with my finger off the shutter button. Canon 40d
crn3371 Cream of the Crop 7,198 posts Likes: 2 Joined Mar 2005 Location: SoCal, USA More info | Oct 22, 2006 18:22 | #11 If you are using the focus, recompose, shoot, method on your tripod with your kit lens, chances are that you aren't going to shift your shutter plane enough to effect focus. Wide open, on a fast lens, possibly. But I doubt it with your kit lens. If you want to make sure, why not compose your shot correctly ahead of time, using an off-center focus point.
braduardo Goldmember 2,630 posts Likes: 1 Joined Jun 2006 Location: Minneapolis, MN More info | Oct 22, 2006 18:31 | #12
If I don't want to switch from center-point AF, I will focus with the center on what I want exactly in focus, then rotate the camera to compose... Here's an example... (Not the greatest, just quick example). Center focus - Normal:
Center focus - Focus on foreground then recompose:
Notice how in the first one, the DOF is shallow enough that I can't get everything in focus, so only the middle is good. I didn't like the effect, so I decided I wanted to put the graves closest to me in focus, and let the DOF fade towards the back. The technique works well if you don't have an AF point where you want to position your subject. You just have to be careful, because if you move the camera too much, you will end up with an OOF image.
braduardo Goldmember 2,630 posts Likes: 1 Joined Jun 2006 Location: Minneapolis, MN More info | Oct 22, 2006 18:32 | #13 Having said the above, I would still recommend composing your shot first, then not changing it. If you are trying to take a picture of a candle, you might want to just manually focus on it.
Oct 22, 2006 22:00 | #14 If I understand it correctly, you are using the timer because you do not want to have to keep the shutter button held down halfway to keep focus locked while recomposing the shot? There are two easier solutions: Comments, bribes, criticism, bribes, irrelevant anecdotes, and bribes always welcome.
| Latest registered member was a spammer, and banned as such! 2695 guests, 145 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
