When you upload your weddings pics on the computer, what cable do you use? After shooting weddings the amount of pics to upload is huge and my USB cable is just darn slow. What cable do you use and how fast/slow is it?
song4themoon Goldmember 3,039 posts Joined Dec 2005 Location: Maryland More info | Oct 23, 2006 10:31 | #1 When you upload your weddings pics on the computer, what cable do you use? After shooting weddings the amount of pics to upload is huge and my USB cable is just darn slow. What cable do you use and how fast/slow is it? www.forever-yesterday.com
Banbert Goldmember 1,514 posts Joined Jul 2006 Location: Leamington Spa, UK More info | Oct 23, 2006 11:19 | #2 Permanent banI always upload mine via a USB2 card reader, I never plug the camera in directly. Warwickshire Wedding Photographer
Oct 23, 2006 11:32 | #3 I used the reader too and it took the same amount of time if not longer. I was told that there are other cables, that are much faster? www.forever-yesterday.com
sblais I am silly 3,532 posts Likes: 3 Joined Oct 2006 Location: Ottawa, ON (Canada, eh!) More info | Oct 23, 2006 11:35 | #4 You're PC determines what USB port you have. If it USB ports are directly on the motherboard, then the only option to go to USB2 is to change that board... which means that you should probably upgrade your PC altogether (change motherboard, CPU, RAM, but keep your hard drives). Sebastien
Oct 23, 2006 11:37 | #5 hmmm... ok thats stuff I have no clue about and need to ask my husband. We just bought that PC 1 1/2 years ago or so. www.forever-yesterday.com
sblais I am silly 3,532 posts Likes: 3 Joined Oct 2006 Location: Ottawa, ON (Canada, eh!) More info | Oct 23, 2006 11:37 | #6 The cable itself doesn't affect the connection speed. An expensive cable (worthless, IMHO), will only insure that the connection is good and that the signal transmitted is free of noise, etc. So unless you have problems transferring altogether (e.g. it may stop in the middle of a transfer for no reason, etc), then your cable is fine. Sebastien
sblais I am silly 3,532 posts Likes: 3 Joined Oct 2006 Location: Ottawa, ON (Canada, eh!) More info | Oct 23, 2006 11:39 | #7 Yeah, it really depends on the motherboard. Fairly new PC (1-2 years old) may still have USB 1.1. It may be possible to add an extra card (PCI) to the PC that would allow you to have USB 2.0 (along with your already installed USB 1.1). But I haven't really checked those as I don't need one Sebastien
Scott_Quier Senior Member 888 posts Joined Jul 2006 Location: Newport News, VA More info | Oct 23, 2006 11:50 | #8 sblais wrote in post #2157961 You're PC determines what USB port you have. If it USB ports are directly on the motherboard, then the only option to go to USB2 is to change that board... which means that you should probably upgrade your PC altogether (change motherboard, CPU, RAM, but keep your hard drives). If you are talking Apple computers the above my very well apply. I have no knowledge of Macs. sblais wrote in post #2157976 Yeah, it really depends on the motherboard. Fairly new PC (1-2 years old) may still have USB 1.1. It may be possible to add an extra card (PCI) to the PC that would allow you to have USB 2.0 (along with your already installed USB 1.1). But I haven't really checked those as I don't need one . If you are talking about a desktop PC, it's easy & cheap to get a USB 2.0 PCI card and install it into an expansion slot on the M/B. These cards may/should come with a driver to make all the components happy. Scott
sblais I am silly 3,532 posts Likes: 3 Joined Oct 2006 Location: Ottawa, ON (Canada, eh!) More info | Oct 23, 2006 12:03 | #9 Scott_Quier wrote in post #2158018 If you are talking Apple computers the above my very well apply. I have no knowledge of Macs. I was talking PC all the time, but forgot to mention about PCI cards... only thought of it a few minutes later! Sebastien
coreypolis Cream of the Crop 6,793 posts Likes: 4 Joined Mar 2005 Location: Mercer Island, WA More info | Oct 23, 2006 12:41 | #10 Permanent banextreme IV cards with firewire card reader {drool} Photographic Resources
sl3966 Member 232 posts Joined Oct 2006 Location: Annapolis, MD More info | Oct 23, 2006 12:41 | #11 Do you have a firewire port on your pc? Might want to try that out as well as long as your card reader supports it.
Banbert Goldmember 1,514 posts Joined Jul 2006 Location: Leamington Spa, UK More info | Oct 23, 2006 13:03 | #12 Permanent bansblais wrote in post #2157968 The cable itself doesn't affect the connection speed. An expensive cable (worthless, IMHO), will only insure that the connection is good and that the signal transmitted is free of noise, etc. So unless you have problems transferring altogether (e.g. it may stop in the middle of a transfer for no reason, etc), then your cable is fine. That is not correct, yes they are the same connectors but unless its a quality cable thats certified to USB 1.1 or 2.0 its likely that you wont get USB 2.0 speeds out of it. That doesnt mean that you have to spend a lot of money on expensive cables, it just means you should look to make sure that the cables are certified, preferably to USB 2.0 these days given that they dont really cost any more than 1.1 certified cables. Warwickshire Wedding Photographer
Oct 23, 2006 13:12 | #13 not sure if I have a firewire port.. I need to ask hubby.. he knows that stuff www.forever-yesterday.com
wu_wei0 Irrepressibly irresistibly Creamy 12,250 posts Gallery: 1 photo Likes: 1 Joined Sep 2005 Location: You cannot know my location if you are busy measuring my speed More info | Oct 23, 2006 13:19 | #14 YOu can always buy a firewire card and cable if you have empty expansion slots in your pc. for example:
sblais I am silly 3,532 posts Likes: 3 Joined Oct 2006 Location: Ottawa, ON (Canada, eh!) More info | Oct 23, 2006 14:38 | #15 Banbert wrote in post #2158296 That is not correct, yes they are the same connectors but unless its a quality cable thats certified to USB 1.1 or 2.0 its likely that you wont get USB 2.0 speeds out of it. That doesnt mean that you have to spend a lot of money on expensive cables, it just means you should look to make sure that the cables are certified, preferably to USB 2.0 these days given that they dont really cost any more than 1.1 certified cables. Sorry, I failed to mention that I was talking about cables working with the same standards (e.g. comparing 2 USB 2.0 cables). Otherwise, my argument still stands. I was referring to "expensive cables" (see my post) as for the cable freaks (e.g. similar to the "audiophiles"). Sebastien
| Latest registered member is Thunderstream 1418 guests, 113 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
