Thread started 23 Oct 2006 (Monday) 10:42
first 10-20 pic
WildWolf
Joined Feb 2003
Oct 23, 2006 10:42 |  #1
Does this look sharp to you? I also shot with my 24-105 and that blew the 10-20 away. I am wondering if it is because the 10-20 is further away from the subject. Anyway- what do you think?
5DMkIV
Canon 24-105 L IS ; 70-200 L IS II; 100-400 L IS
430 EX; Feisol 3442 w/CB50D; Bogen 681B; POTN strap
MacksQu
Oct 23, 2006 11:06 |  #2
that doesn't look sharp at all.
____
www.maxlindquist.com (external link)
350D w/ kit
EF 85mm f/1,8 USM
WildWolf
Joined Feb 2003
Oct 23, 2006 11:15 |  #3
The camera was on a tripod and I have a few like this. I believe I was at f8. What should I do? Send back to Sigma?
5DMkIV
WildWolf
Joined Feb 2003
Oct 23, 2006 11:16 |  #4
One other thing....I took some pics of a notebook indoors and the writing was extremely sharp (handheld). This does not make any sense to me.
5DMkIV
Dante ­ King
"Cream of Corn" BurgerMeister
Joined Jan 2005
Oct 23, 2006 11:17 |  #5
hard to tell sharpness from size of post. Post at 800 px on longest side and then a crop of 100%
Dante
I am not an Lcoholic. Lcoholics go to meetings!
WildWolf
Joined Feb 2003
Oct 23, 2006 11:32 |  #6
Dante,
How do I do this in CS2? I have the picture on my home computer and can modify and post from there.
5DMkIV
SuzyView
Oct 23, 2006 11:36 |  #7
I had the same problem posting. I made a photobucket account and I use the link to my photos there. Makes the resolution much better. If you are on the internet now, see if you can start an account, then upload the photo to it, I make it 600 dpi 4x6, I save as a JPEG file, like I am printing it at Costco. After downloading onto the site, see below the picture there are links. Click on the IMG and it will highlight the link. Ctrl C to copy and reply here by Ctrl V. That should send the link to the forum.
Good luck!
It does look fuzzy the way you posted it.
John ­ Nicholas
Oct 23, 2006 13:02 |  #8
Very Hard to tell from your post, but I guess you answered your own question....... your 24-105 blew it away.
Canon 30D - Canon 70-200 2.8 IS L
Canon 24-70 L Canon 17-40 L
Canon 1.4 MKII TC
Canon 580 EX
Canon 420 EX
WildWolf
Joined Feb 2003
Oct 23, 2006 19:34 as a reply to  @ John Nicholas's post |  #9
here is 100% crop. No idea what is meant by 800px though:
5DMkIV
WildWolf
Joined Feb 2003
Oct 23, 2006 19:35 |  #10
why so much noise? Is this the lens? ISO was at 400.
5DMkIV
WildWolf
Joined Feb 2003
Oct 23, 2006 19:36 |  #11
btw- this could be from a different picture in the series. They were all shot within the same burst.
5DMkIV
Broncobear
Oct 23, 2006 19:38 |  #12
This was on a tripod?, I would send it back or return it if you just recently bought and exchange it for another lens.
"The real voyage of discovery consists not in seeking new landscapes, but in having new eyes." " (external link)Marcel Proust (external link)
Gear& Frank's Flickr (external link)
WildWolf
Joined Feb 2003
Oct 23, 2006 19:39 |  #13
100% crop with the 24-105 wide open:
5DMkIV
Bob_A
Gallery: 48 photos
Joined Jan 2005
Oct 23, 2006 19:41 |  #14
WildWolf wrote in post #2159932 (external link)
Was the image quite underexposed? If you corrected the exposure a fair bit in Photoshop or during the RAW conversion you will see significantly more noise and a loss of detail.
Bob
oldradioman
Oct 23, 2006 21:32 |  #15
WildWolf,
It is very difficult to qualify lenses without some type of controlled environment. The following is a method I have used with good results.
Make a test pattern. This can be an 8.5X11 sheet of paper placed in landscape with some words in the middle. The letters should be about 1/4 inch high, black, bold and printed with a good printer. Mark each corner with a black brush pen so they are very obvious.
Mount this target on a board at the same height as your tripod mounted camera and give it good lighting.
Mount the first lens on the camera and adjust for lowest number focal length.
Adjust the distance between the camera and target so the target just fills the frame. Take your first picture. (should be high resolution)
Increase focal length to the highest for that lens or some intermediate point on a zoom lens with longer range. Repeat the above step and take your second picture. Continue for as many test shots you may want.
View the text on each picture at 100% and note the sharpness. For example, this test will very often indicate if a lens is soft at full zoom and can be used to compare two lenses. Text can also be placed along the edge of the target to determine edge sharpness.
If the lens(es) produce sharp text under these conditions, pictures in the field should be sharp as well if adjusted properly.
This is by no means the most accurate method although, with the minimal time and material required, fairly reliable results can be obtained.
Good luck
Arvid
Canon EOS 40D, EF-S 17-85mm IS, EF 70-300 IS DO
Sigma 70-300mm DG Macro
Tamron 1.4X TC, 200-500, 180mm DI LD Macro 1:1
Nikon CP5700, Nikon 1.5X TC
Paint Shot Pro Photo X2
1,952 views & 0 likes for this thread, 12 members have posted to it.
first 10-20 pic
2648 guests, 154 members online
