Note: whenever I say "Bridge", I mean ACR...
Several times, I have started to put together images that show the differences between Bridge (ACR), DPP and CS2/PS. For this discussion, I have not bothered and thought it would be a good topic to discuss amongst seasoned pros. (I actually wanted to take the time to develop a mouse-over flash presentation that shows the difference directly)
First, let me state that I have been a graphic arts professional for over 20 years. I have been in the digital mainstream for over 12 of those years. So, I know a little about system color calibration and the correct ways to use programs, drivers, settings, etc. (note: I am not saying I know everything) I also have absolutely no problem getting DPP and PS perfectly in sync. (to what I saw originally) The images between the two are 100% identical. (the way they should be) I should also say that if I never see the DPP preview that Bridge and PS are in sync. (to me, but darker and subdued)
However, since day one of owning my 30D and DPP, I have absolutely loved the fast workflow for general base editing, overall vividness and accuracy of the 'what I saw' that I get from using Digital Photo Professional (DPP) over Bridge (ACR). DPP seems more true to life and vivid as I remember seeing the actual scene or subject. Obviously, as a graphics arts professional, I have enjoyed using PS for many years (since version 2 actually), and most recently, Bridge in the past year for workflow features. However, the accuracy between Bridge (ACR), DPP (or specifically, the CR2 file itself) and PS in regards to photographic files and their default color, brightness, accuracy, etc continue to baffle me.
Bridge (ACR) has a tendency to subdue images when it opens them. This is a fact. I have personally disabled all of Bridges "auto adjustments" in hopes of seeing the same image I would see in DPP on default camera shot settings. The problem is, it's impossible. (without faking it by setting your own "changing adjustments" in Bridge) It does get closer, but still is not as accurate in color, or mainly brightness, as the original DPP preview and what I remember.
I shoot in sRGB. I edit in sRGB. Why? I use SmugMug and this is the way they are set up for consumer printing. (among many other 'photo' printers online) By using their profiles, prints are accurate. If you do not have a working background in offset printing and can explain to yourself the difference between why you choose AdobeRGB1998 over sRGB then do not bother to respond to this thread. (your time will be wasted) This discussion will be based on sRGB editing only. (if you are currently using AdobeRGB1998 and do not do CMYK offset or commercial printing, you might be interested in reading SmugMug's description of why you should be in sRGB mode... it's very enlightening to those who don't have a background in printing and are mainly photographers... this goes for all you in-house Epson owners too
The bottom line is Bridge should not look any different than DPP in a default image preview (again, default shot settings) when the color settings, space, etc are identical. So, why does it? Is this a software issue with Bridge and how it reads the original file? Or is this a problem of DPP being 'too' vivid? Personally, I think DPP is much closer to accuracy regarding the actual subject, color, lightness, etc than Bridge (ACR) is.
Professionals, run your own tests... don't worry about print output at this time... lets only discuss why we think the viewing accuracy is different in Bridge, regarding the original image at it's default camera shot settings in comparison to the DPP preview of the same thing. If you feel Bridge is more accurate in regards to the original subject, color, brightness, etc - feel free to discuss that as well.
I challenge you to not reply until you have tested this yourself. I am not looking for a debate here; but a discussion with possibly a conclusion on where we need a solution.
Discuss...
