Thread started 24 Oct 2006 (Tuesday) 07:20
50mm f/1.8 and sunsets....
ChrisBlaze
Oct 24, 2006 07:20 |  #1
since the fiddy is sitting open at 1.8, would it be good to take pics of sunsets?
Canon 1D Mark II N/5D Mark III/ 6D/ 7D /85mm f1.2L Mk1/ 24-70 f2.8L/ 70-200mm f2.8L IS USM/ 100mm Macro f/2.8
Honolulu POTN
PAFC2004
Oct 24, 2006 07:21 |  #2
You can stop it down...
Canon 5D MKii |Canon 350D | EF 17-40L | EF 70-200 2.8L | 580EX II | 430EX | EF 1.4x T/C II | EF 50 1.8II | Q6600 + 8800 Ultra
ChrisBlaze
Oct 24, 2006 07:27 |  #3
with it being a prime, would it be sharper than my kit lens? (refering to the sunset photo)
Honolulu POTN
PAFC2004
Oct 24, 2006 07:32 as a reply to  @ ChrisBlaze's post |  #4
Yes, especially stopped down.
ChrisBlaze
Oct 24, 2006 07:40 |  #5
thanks
Honolulu POTN
Double ­ Negative
*sniffles*
Oct 24, 2006 10:29 |  #6
Sunsets will likely be too bright to shoot wide open anyway, and you'll definitely want to stop it down to say f/5.6-8.0 to get the sharpest image.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
ChrisBlaze
Oct 24, 2006 10:32 |  #7
Double Negative wrote in post #2162494 (external link)
wouldnt f/8 not give me the sharpest image. I thought that the lower the f-stop the less things are in focus. Most of my sunsets was taken at f/12-18.
Honolulu POTN
In2Photos
Oct 24, 2006 10:35 as a reply to  @ ChrisBlaze's post |  #8
It does an OK job.;)
Current Gear and Feedback
ChrisBlaze
Oct 24, 2006 10:44 |  #9
In2Photos wrote in post #2162521 (external link)
what lens and f-stop was this taken?
Honolulu POTN
SimonG
Oct 24, 2006 10:48 |  #10
The EXIF info is in tact eh... it was taken with his 50 mm @ f/11.
-- Michael (a.k.a. SimonG)
EOS 5D | 17-40 f/4L | 24-105 f/4L | 40 f/2.8 | 50 f/1.4 | 85 f/1.4 | 430EX | Zenfolio (external link)
In2Photos
Oct 24, 2006 12:29 |  #11
SimonG wrote in post #2162567 (external link)
Thanks Mike. Although this particular shot was taken with the POTN Nifty Fifty that is floating around the world, not my particular copy. Either would have taken the same photo though.
blam
Oct 24, 2006 12:41 |  #12
shooting wide open with the nifty in that situation will get you a softer image than a stopped down shot.
I believe most lenses will always give you the sharpest image stopped down a little...
Double ­ Negative
*sniffles*
Oct 24, 2006 12:43 |  #13
ChrisBlaze wrote in post #2162505 (external link)
You're confusing DoF with sharpness. The smaller the aperture, the greater the DoF. Most lenses don't reach maximum sharpness until at least f/5.6 typically. So beyond that you're in the "sweet spot" until you get to f/16-22 or so, where diffraction starts to adversely affect your image.
Besides, no point in having a huge DoF unless you have foreground objects in your scene. The horizon/sun is for all intents and purposes "flat" and at infinity.
To really maximize the DoF where you do have foreground objects, set your lens to the "hyperfocal distance."
blam
Oct 24, 2006 12:45 |  #14
double neg nailed it.
http://members.shaw.ca​/br.l/50mm.htm (external link)
this is an example of sharpness wide open vs stopped down...
ps. the 1.4 loves light. my shutter maxed out on the first few shots.
7.1 is super sharp vs, 2.8 even
4,041 views & 0 likes for this thread, 6 members have posted to it.
2652 guests, 154 members online
