Ok, I am still mentally processing why I should shoot more RAW. In another thread a very detailed explination was given that with canon 12 bit raw, you get many more levels of color rendition because of RAW. It was something like 256 levels versus 16 in JPEG. And that sounds interesting when trying to perserve shadow detail best you can. But where I get lost is when I open that file in PS, it is going to automatically upsample that to 16 bits. There is no 12 bit format for editing. I know from my 16 bit work I get 64,000 levels... so where and how does that upsampling happen? When you change Gamuts there are all kinds of different ways to derive the right dirstribution of color bandwidth so that it doesn't loose it relativity to the rest of the colors. Yet when I am done in my RAW setup and click "open", I don't get any options for color handling or rendering intent. So when I click open, to fill in the blanks, PS is doing what to fill in that extra color depth that just became available?
Educate me some of you RAW gurus. I have sort of bought off on this - but there still is color change going on that seems your are not in control of. Also, just to be clear - when you do JPEG compression at levels like 10+, it isn't necessarily dumbing down any colors rather it is looking for color patterns repeated in the image, and then referencing that pattern multiple times rather then storing that pattern multiple times. The higher the level of compression, the more generic those color patterns become and yes then you loose detail. But from what I remember from readings in the original jpl documents, it is referential, not distructive. Just a side note.
