Thread started 24 Oct 2006 (Tuesday) 20:42
Circular Polarizing Filters - Uncoated and Coated Images
agatep
Oct 24, 2006 20:42 |  #1
There is much talk about the image quality of uncoated and multicoated circular-polarizing filters. High-end multi-coated CP filters are commonly recommended, but are relatively expensive.
I am unable to find any resources comparing images between low-end and high end filters.
Can anyone show me the image differences between low-end and high-end filters from the same company?
Someone (not working for the manufacturers) needs to prove to me that there is really a difference.
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Oct 24, 2006 21:04 |  #2
agatep wrote in post #2164957 (external link)
Buy some of the cheap ones and post the images. I am sure that we would all be interested. Not sure why we would need to prove to you the difference. It is really a personal thing.
Doc Klepper in the USA
I
freefallu
Oct 24, 2006 21:11 |  #3
I would be interested to know also if its worth paying the extra.. which i think is OPs question.
Cheers David Cowman
Canon 5d, 400D , 24-105 L IS :: 70-200 f4 L :: 50 mm f1.4 :: Sigma 15mm f2.8 :: Canon 35 f1.4L :: Canon 85f1.2L 580EX x 2 ,ST - E2 , 2x Quantum turbo 2x2 batteries, Various flash devices from lumiquest and Stofen. Studio: 2 x Bowens 500 with lots of stuff to complement.
SkipD
Joined Dec 2002
Oct 24, 2006 21:36 |  #4
Quality glass used in filters will prevent distortion of an image that is possible with cheap filters that are not optically flat. Multicoating of a filter's surfaces helps to reduce (but will not necessarily eliminate) flare from high-intensity light sources that impinge on the filter.
The above is true for ALL filters, not just polarizing types.
Skip Douglas
Skrim17
Oct 24, 2006 21:38 |  #5
what is considered cheap and what is expensive?
Crissa
SkipD
Joined Dec 2002
Oct 24, 2006 21:55 |  #6
Skrim17 wrote in post #2165179 (external link)
My use of the word "cheap" does not necessarily relate to price. It's lousy quality of construction that I call "cheap". Usually junk filters will also have a low price, but that is not always true. Often, it's "buyer beware".
Sticking with the better name brands (such as Hoya, B&W, and Heliopan) - and making sure the characteristics of the filter (such as multicoating, the material that you want for the threaded ring, etc.) are what you are looking for is the best way to be assured that you are buying a quality filter.
Skip Douglas
freefallu
Oct 24, 2006 21:58 |  #7
thanks for the informative post.
Cheers David Cowman
Tsmith
Formerly known as Bluedog_XT
Oct 24, 2006 22:08 |  #8
This is why you don't want to buy El' Cheapo quality filters. I learned my lesson after this outing last summer in New Orleans. 75% of my photos looked like this from that afternoon. Since then in all types of conditions I haven't had an issue with my Hoya Pro1 Digital Circular Polarizers.
Double ­ Negative
*sniffles*
Oct 25, 2006 13:49 |  #9
You won't see many cheap samples because the images produced aren't keepers. ;)
Seriously though. It pays to get a GOOD filter. Heliopan and B+W make the best available. Hoya Pro1 are also good. The more coatings, the better.
At the bottom of the heap are Canon (a.k.a. Tiffen), Quantaray (Ritz Camera), etc.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
Tareq
"I am very lazy, a normal consumer"
Oct 25, 2006 14:02 |  #10
Double Negative wrote in post #2167989 (external link)
Can you name or link to some of these C-PL? i had 2, Cokin (77mm) and Marumi (58mm) both working good but i am not sure if they are enough good in many situations, in addition i got many lenses now and i need one more C-PL 77mm for most of my lenses (10-22, L:16-36, 24-70, 70-200, 100-400)
Galleries:
http://hamrani.deviant​art.com/gallery/ (external link)
Facebook (external link)
Nick_C
Oct 25, 2006 14:30 |  #11
Cheap filters are fine if you understand their limits, I use a real cheap polariser & may get a better one when I can get enough cash together, 72mm on my sigma lens are not cheap, I dont get any problems though.
So long as you dont go pointing the lens where sun can cause glare its fine, ive had a few situations where im pointing with the sun almost in the corner of the image, but my lens hood takes care of most flare problems.
The best would be expensive filter + hood, then you wouldnt get any problems, if you still get some lens flare, then even without the better filter it would have been a problem, after lots of tests I found under the worst flare conditions filter or no filter, it wasnt any good, a coating on the lens can only do so much, the Hoya Pro1 filters £ for £ are more expensive than any L lens, imagine having 12 elements made up of hoya Pro1 priced glass, it would be a damn expensive lens!! lol..
At the end of the day, you get what you pay for, try a cheapy, but if your doing shots that are critical then dont risk it, get a decent one, at least you would have done all you can then to get the best out of your kit.
Nick :-)
Double ­ Negative
*sniffles*
Oct 25, 2006 15:00 |  #12
Tareq wrote in post #2168053 (external link)
You can find these filters at any reputable distributor...
Cheap filters work - assuming you know their limits as Nick says. Hey, I've got a Marumi or two myself floating around.
Stick with the better Hoya filters and make sure it's multicoated - or better.
One thing you can do to reduce cost is buy the largest CPL you'll forsee needing (e.g. 77mm) and just get step-down rings for other lenses. One word of caution though; you can't step down too much (meaning the CPL would be too big) because of interference with the lens hood - and one wide angles such as that 10-22mm, you'll vignette if you try this. Best to get a properly sized and "slim" version for use on that lens.
Wilt
Oct 25, 2006 15:03 |  #13
Hoya markets multiple lines of filters...about 5 of them, I think! At the bottom are the Single Coated, next up is Hoya Multicoated, next up is the Super Multicoated, higher up are the Digital Pro. Per claims, each is more efficient in light transmission (passing more of the light thru) and preventing reflections (letting less of it bounce off the filter surfaces). If I recall, the single coat passes 93%, HMC passes 97%, SHMC passes 99.7%, and the digital have coatings on the filter edge for further reduction of light bouncing off surfaces 'because digital is more vulnerable' (my words).
Under the right conditions you CAN see the difference in filter quality. Lowered contrast, more reflections, in side by side test photos.
Tareq
Oct 25, 2006 15:20 as a reply to  @ Wilt's post |  #14
I was worry if i travel if i need better C-PL filter but i think the sun there is not strong enough or say disappeared most of the time behind clouds so then i don't need that expensive filter, but in my area, even you are at home you feel the heat and strong light of the sun, so means you need something to prevent most of the sun x-ray or flares or even reflections.
Anyway, i used cheap C-PL on my shots of Ajman beach in Landscape section and i don't know if they are good enough.
Galleries:
DocFrankenstein
Joined Apr 2004
Oct 26, 2006 09:32 |  #15
agatep - if you don't beleive the hype - get the cheap one. You'll find out for yourself if you like it or not.
National Sarcasm Society. Like we need your support.
2,927 views & 0 likes for this thread, 12 members have posted to it.
1403 guests, 141 members online
