Thread started 26 Oct 2006 (Thursday) 02:38
Do I have a Problem with my EF 100-400mm
arkturas
Oct 26, 2006 02:38 |  #1
Folks, Just returned back from South Africa - had an awsome time. here are some of the results.
All pictures were taken using a Canon 100-400
https://photography-on-the.net/forum/showthre​ad.php?t=231497
but here is my problem some of the images seem to show some noticable ghosting.. here is an example
what could be the problem me or the lens....
Exif Data:
Shutter Speed: 1/250th
Apeture: f5.6
Focal Length : 400mm
ISO 400
Metering: Pattern
Set to AV MODE on 30d
Gear: a camera and some lenses
CarlEOgden
Oct 26, 2006 02:57 |  #2
Focus appears not to be on the bird but the branches.
Carl.
evandavies
Joined Feb 2006
Oct 26, 2006 04:36 as a reply to  @ CarlEOgden's post |  #3
arkturas, do you have a UV filter on?
I had similar effects with some of my pics and it seems to have been caused by the UV filter.
E:¬D
- Gallery - (external link)
= Gear =
Lens focuses the light,
camera records the light,
you make it art.
arkturas
Oct 26, 2006 06:03 as a reply to  @ evandavies's post |  #4
Yes I was using a UV filter, its a Hoya £30 pounder - looking now the ISO setting is far too high and I should have set the apeture to atleast f8 instead of f5.6.
arkturas
Oct 26, 2006 08:01 |  #5
any other comments - I really want to get to the bottom of this
aaronmd
Oct 26, 2006 09:17 |  #6
Odds are that the ghosting is due to the UV filter which you have on the lens.
www.aaronmacdougall.co​m (external link)
evandavies
Joined Feb 2006
Oct 26, 2006 09:26 as a reply to  @ aaronmd's post |  #7
99% sure its the filter
E:¬D
= Gear =
you make it art.
arkturas
Oct 26, 2006 10:28 |  #8
Thanks gents
Janika
Oct 26, 2006 10:44 |  #9
Should of used spot metering on your 30D and center focus point only for these shots to ensure focus accuracy. I also have a UV filter for my trombone, but don't use it, as I don't believe in those. If anything, I would of taken a cir polarizer there...
(John) CANON A590 iS - EOS 50D - EF 400mm f/5.6 L USM - EF 50 f/1.8 II - Tamron 17-50 f/2.8 XR Di II - Velbon Sherpa pro - SIGMA DG500-ST
EOS 40D sold, EF 300 f/4L iS Sold
Rhinotherunt
Looking for a Rock
Oct 26, 2006 10:47 |  #10
I would say the UV filter...
Ryan McGill
My Gearhttps://photography-on-the.net/forum/showthre​ad.php?t=592450
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Oct 26, 2006 10:55 |  #11
Looks like a cheap UV filter, try the Hoya pro 1 SHMC ones.
Alternatively a similar problem can happen if you shoot through a window.
Macrophotography by LordV
Rhinotherunt
Looking for a Rock
Oct 26, 2006 11:04 |  #12
Lester Wareham wrote in post #2171990 (external link)
Yeah, if you are in a vehicle shooting these images through a window... This is probably what caused it.
Ryan McGill
curiousgeorge
Gallery: 13 photos
Joined Feb 2006
Oct 26, 2006 16:41 |  #13
Why has no one mentioned the shutter speed??
1/250 is way too slow at 400mm, especially if the vehicle is idling.
I'm not convinced about the UV filter, but to put your mind at rest you should do some tests with and without anyway.
I've seen your other pictures and they look fine. I presume the filter was on for those too.
Photos from my travels (external link)
Canon EOS R6 MkII | Canon EF 24-70mm f/4L | Canon RF 100-500mm f/4.5-7.1L | Samyang 14mm f/2.8
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Oct 26, 2006 17:25 |  #14
I use UV filters under one condition. If the conditions are so harsh so as to require protection of the lens. In Africa that might be the case. There are only 2 filters that I would use B+W Multicoated F-Pro and Heliopan. A cheap filter on a good lens is not good practice.
Doc Klepper in the USA
I
Keith ­ R
Oct 26, 2006 19:22 |  #15
curiousgeorge wrote in post #2173490 (external link)
Not with an IS lens it ain't, George...
Looks like a filter thing to me too.
2,555 views & 0 likes for this thread, 12 members have posted to it.
2744 guests, 154 members online
